Silicone Radiator Hose Kit?
Old 02-12-2011, 10:40 PM
Y2K XKR's Avatar
Default Silicone Radiator Hose Kit?
Any one know where I can get red silicone radiator hoses for a 2000 XKR? Paragon has them but they want 450 British Pounds or about $720 - WAY too much. http://www.paragondesignuk.com/engine.htm I've tried every search I could think of but I came up with no other options. I have a red coupe and I think the red hoses would look cool...
Old 02-12-2011, 10:43 PM
Y2K XKR's Avatar
Yea! I've graduated to "Member" status...
Old 02-13-2011, 12:05 AM
Nce Kty's Avatar
Welcome to the Forum! I know you'll find the info here valuable.
I hope you find the hoses you're looking for at a good price.
Maybe if you can work with this company
http://www.viperperformance.co.uk/ta...php?xscId=9759
they can make a set for you at a good price so you can help them to enter the Jaguar market.
Good Luck and let the forum members know about your quest.
Old 02-13-2011, 12:14 AM
Reverend Sam's Avatar
Received 1,258 Likes on 564 Posts
$720 for a frikken radiator hose? Braided aviation quality hoses are 1/4th that price!
Old 02-13-2011, 12:23 AM
2000blackxkr's Avatar
Wink hoses
A little Bird told me that Nameless Performance may be working on such a kit.
Old 02-13-2011, 02:50 AM
XKRacer's Avatar
I dont think that is too much, there are a lot of hoses in an XKR set and it includes the T pieces you will need with Mikalor clamps. The T pieces are non standard and have to be made, it all adds up.
I must admit I don't know anyone else who does them as the demand is so low and the cost of getting the tooling made is high. But you ought to try and compare the cost to other performance cars even things like Skylines you will pay more than the XKR set for a lot less hoses.
Y2K XKR (02-13-2011)
Old 02-13-2011, 02:56 AM
XKRacer's Avatar
But they are not shapped or made to order are they, and to be fair it is not $720 for a radiator hose, it is $720 for every single hose there is on an XKR engine thats a minimum of 15 and if you want to go mad I will supply all the small ones for the header tank for free
Old 02-13-2011, 10:22 AM
Ah... I didn't realize that was for all of the hoses. For some reason I was thinking it was $720 for a single hose.
Old 02-13-2011, 11:37 PM
Y2K XKR's Avatar
XKRacer, I've seen your posts dozens of times and although it's in your signature block, I didn't realize until now that you were associated with Paragon Designs sorry about that. I get the fact that the production numbers would be low for such a limited production vehicle but you have to admit the price is off-putting for the regular Joe. My water pump went south last week so I'm doing a T-stat, pump, flush and refill - I'd love to add some nice red silicone hoses but I just can't afford em right now.
Ken
Old 02-14-2011, 02:17 PM
XKRacer's Avatar
Don't worry yourself, but yes I am Mr Paragon if you like , 95% of everything you see on that site is made by me.
It is possible to do a fair amount of the hoses with simple elbows and connectors like the pic below.
But as you can he was a missing a few 'awkward' shaped hoses, which I supplied for him, I have no problem with just supplying certain hoses that are needed.
Old 02-14-2011, 09:38 PM
Y2K XKR's Avatar
Very nice "Mr. Paragon!" Engine dress-up is on my list but for now I have to stick to the routine maintenance.
Old 05-10-2014, 02:23 PM
Beavis's Avatar
Digging up a very old thread here - but XKRacer, if your still around, can you\will these sets fit a 2004 XJR?
Old 05-10-2014, 09:52 PM
giandanielxk8's Avatar
Received 1,339 Likes on 724 Posts
Tony, I just noticed he modified the intake tube with silicone hoses. The acordeon area of my intake tube is cracked and it is causing an intake leak. I have remedied this with silicone, electrical tape and duct tape until I could buy a new one.
How hard would it be for me to just remove the accordeon area of the intake tube and replace it with something like what he did? Is it advisable? From what I'm seeing he used a silicone hose and clamps. What other materials can I use that would provide the same needed flexibility?
Old 05-11-2014, 09:31 AM
The Coupe's Avatar
Check your dealer's pricing on this item...the air intake tubes are often priced much lower than you might imagine. Lots of them crack, so many are replaced and the parts are plentiful.
Old 05-11-2014, 11:14 AM
I recently learned that we no longer have a Jag dealer in my country. I'd have to buy online or from a parts shop, which tend to mark up the price.
Old 05-11-2014, 08:26 PM
mjlaris's Avatar
I bought my hoses from Paragon and like them very much.
Mark
Attached Thumbnails Silicone Radiator Hose Kit?-wp_20140322_17_50_28_pro.jpg
Old 05-12-2014, 03:31 AM
XKRacer's Avatar
Maybe....... The only real difference will be the radiator hoses, I will take a look at my XJR which is a 4.0 but I would expect to be very similar as is with the XKs
Not that hard to do, get yourself a 80mm 45* degree and a 90* degree, you will also need 3 silicone joiners with clamps, cut the throttle connection to allow the 90 to fit over and use the silicone joiner to seal. Join the 45 to the 90 with another silicone joiner and then at the end of the 45 again with another joiner connect to your MAF...... You can buy everything on eBay
giandanielxk8 (05-12-2014)
Old 05-13-2014, 03:48 AM
Beavis's Avatar
[QUOTE=XKRacer;973544]Maybe....... The only real difference will be the radiator hoses, I will take a look at my XJR which is a 4.0 but I would expect to be very similar as is with the XKs
Great, thanks - PM me when you know. Would you fit them?
Old 05-13-2014, 03:49 AM
Beavis's Avatar
Very nice... :-)
Old 05-13-2014, 04:18 AM
XKRacer's Avatar
Can you post a pic of the engine bay particularly showing the radiator....... Yours being a X358 could make things a little different, are there all those plastic covers in the way??
The XJs may look similarish from the outside from the X308 but under the skin they are totally different animal and looking at mine (X308) I reckon using the XK set would just about work.
No worries about fitting, I will not deny I have not had much experience with X350/8 but happy to have a go
Quick Reply: Silicone Radiator Hose Kit?
