code reader
code reader
Need help to find plug for code reader on my 2006 XK8. I looked around under the dash. Must be looking in the wrong place. Guy at Auto Zone tried no luck. I have engine light on, hope it's bad gas went on 50 miles after I filled the tank, engine runs rough just like bad gas.
Thanks for your help.
Rich
Rich
Rich
Rich
Go to www.CanOBD2.com you will find a graphic pic of where it is. My link on a 04 XJ8 is to the far right of the driver's foot well. I run my hand down along the joint of the center consol and the bottom of the dash and I find an opening and there it is.
JAG06 (03-05-2011)
JAG06 (03-05-2011)
Everything! It's awesome. It lets me read codes, of course, but it also gives me tons of real-time info. For example, I can set it to show my fuel pressure, engine coolant temperature, throttle position (0%-100%), RPMs, engine load (0%-100%), intake air temperature, mass airflow rate, timing advance... It also has graphs that show different parameters over time. On my Expedition it shows me horsepower and torque, but for some reason it doesn't show that on the Jag. It can use the phone's GPS to measure speed, and you can see your GPS speed and your car's wheel speed sensor speed side by side. It's very cool...
Hi govatos:
Have you considered the Kiwi Wifi for the iPhone?
Hardware: http://www.plxkiwi.com/kiwiwifi/hardware.html
Software: http://www.plxkiwi.com/kiwiwifi/software.html
Use this link to view a host of OBD II readers that has been tested and found to work on our cars. https://www.jaguarforums.com/forum/s...ad.php?t=33347 Hope this helps!
Engine light on runs rough
Rich
Rich
Karl
Just in case somebody is wondering now that this popped up. Go to this site:
Welcome to CanOBD2!
Look for DLC Locator in the lower right hand corner of the page.
Welcome to CanOBD2!
Will P
09-19-2018 08:36 AM
derek15301xjr
10-20-2015 07:39 PM
