Transmission fluid change 2005 XK8
I was a little amazed at the prices you get charged stateside.
We only have 2 x ZF accredited specialists in the UK, here's the one I use:
Auto Repair Tollcross, Glasgow | Mackie Automatic & Manual Transmissions
Their price for a fluid/filter change is £151/$183
At that price I could get it done as often as I want I asked them how they could do it so cheap and they advised that they buy the fluid in 1000's of liters at a time and the filters in their 100's
The kicker is they use the correct fluid and flush through the tranny and convertor, meaning you get 100% new fluid.
Yep it's an 800 mile round trip for me, but I make a weekend of it in Bonnie Scotland and realistically it only costs me £90/$110 in fuel (LPG at £0.45ppl/£2.00 per UK gallon)
A note for XK8newbie as I don't see an answer to his question: the filter is integral to the plastic style transmission pan and cannot be cleaned, nor can it be non-destructively forced apart as far as I could tell! The earlier style metal pans had separate (metal) filters that could be changed. Whether the earlier design would fit seems a bit uncertain, whether the steel pan's paper gasket works as well as the rubber O-ring-like gasket on the plastic type is questionable, and whether changing over is cost effective for an every 60k fluid / filter job seems doubtful.
A metal pan is technically available for the 6HP26. Great information here:
6hp26-plastic-to-steel-oil-pan-conversion-kit-222-59.html
