Type (BRANDS) of coolant can I use? - Jaguar Forums - Jaguar Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 05-19-2012, 02:35 AM
Post Type (BRANDS) of coolant can I use?
For my 2000 XKR, I am wondering if anyone can tell me what type (BRANDS) of coolant can I use to top off my car? My "Engine Coolant Low" message appeared today along with the "Performance Restriction" message a few minutes later. Any help is greatly appreciated. I'm fairly new to this forum. Thanks!
Old 05-19-2012, 05:52 AM
GGG GGG is online now
Photobucket
I understand it would be easier to just pick up a particular BRAND but you need to check for the coolant SPECIFICATION.
Brands can cover a range of specifications, some of which are suitable for your XKR and some aren't. What you're after is:
Orange Extended Life Coolant conforming to WSS M97B44-D
This information will be on the label.
One BRAND that markets this specification in the US is PRESTONE'S Orange "5/150 Extended Life AntiFreeze".
Old 05-19-2012, 02:41 PM
Graham gave you excellent advice. Go with orange-colored coolant that meets the M97B44-D spec, and you'll be good to go....
Old 05-19-2012, 06:57 PM
I got the same message, low coolant, a month after I got my 01. I went and got Dexron and have had no problems since, it really was just low no leaks either. I think it had sat at the dealer for a while.
Old 05-19-2012, 08:02 PM
Beav's Avatar
Uh... Dexron is automatic transmission fluid. I think you meant Dexcool.
Old 05-19-2012, 08:41 PM
yes, I knew it was some "dex".
Old 05-19-2012, 08:50 PM
Photobucket
Well "Dex knows"!
Old 05-19-2012, 09:31 PM
Cerberus66's Avatar
It seems on the landy forum they rec anything BUT dexcool.
Old 05-19-2012, 10:39 PM
Beav's Avatar
I've said it before, I don't like Dexcool, but it is the specified coolant.
Old 05-20-2012, 03:46 AM
plums's Avatar
Quote:
Perhaps. But, on a car that has an original spec of Dexcool, then the safest thing for an inexperienced person is to stick with it. It is the only responsible answer to someone whose experience level forces them to even ask the question.
Changing coolant types is an exercise for the experienced who understand the reasons, the risks, the consequences, the required precautions, and the required procedures.
The same caveat applies to any change from original spec coolant type to some other coolant type.
Old 05-20-2012, 08:29 AM
ccfulton's Avatar
Somewhat off topic, but why do people hate DexCool so much?
Old 05-20-2012, 12:38 PM
Some folks believe that Dexcool degrades fittings and hoses. I've used it in our 2004 Lexus RX330 AWD SUV for years with no problems whatsoever....
Old 05-21-2012, 02:12 AM
Thank you everyone for your advise and helpful information.
Old 05-21-2012, 07:45 PM
Beav's Avatar
It just seems, to me, to seep past nearly every connection and leave a crusty mess. Also, again it seems to me, that plastic parts in a DexCool system seem to disintegrate (or at least more quickly) while other coolants don't seem to have that particular issue. I've not seen everything but I have seen a lot over the past forty-two years and these are just my non-documented perceptions.
Old 05-21-2012, 08:27 PM
plums's Avatar
Actually, the Glysantin formulations like Xerex G-05 also leave white stains unless wiped off immediately. Note to readers, Xerex G-05 is *not* a dexcool equivalent. Just discussing staining.
Thread Thread Starter Forum Replies Last Post
AWD and Brake light on 2003 X-Type Shawn Svacha X-Type ( X400 ) 9 05-17-2016 08:19 PM
Overheating issue Raul Lara New Member Area - Intro a MUST 10 09-14-2015 08:31 PM
Center Cap Question - 2002 X-Type (Onyx White) way2far X-Type ( X400 ) 7 09-08-2015 11:32 AM
Questions from a potential owner dcvickers F-Type ( X152 ) 23 09-02-2015 07:14 PM
pepperpot wheel colour prettydaim XJ6 & XJ12 Series I, II & III 8 09-02-2015 06:13 PM
Tags
2005, 98, antfreeze, antifreeze, coolant, fluid, jaguar, jaguars, kind, put, radiator, regular, specications, type, xk8, xkr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
