Searching for remote match
Old 10-12-2013, 01:09 AM
03xk8's Avatar
Default Searching for remote match
My X100 Security & Locking Module 315 Mhz is a LJE2600AB
All I can find is a LJE2610AB key Remote.
Will the 2610 work?
Old 10-12-2013, 02:50 AM
GGG is online now
Received 16,763 Likes on 12,152 Posts
I'll dip my toe in these very dangerous waters of giving advice on remote fobs!
The essential is always to get a replacement remote that matches the number on the back of the original. I'm guessing you never got an original with the vehicle.
The correct fob for your 2003MY will be an LJE2610xx. The problem is the xx suffix. it could need an AA, AB or AC. Only way to be certain is the dealer can identify the correct one from your VIN.
The parts Catalogue does narrow it down to VIN ranges for US models:
to 0442775 : LJA2610AA
from A11051 : LJE2610AB
from A30645 : LJE2610AC
03xk8 (10-24-2013)
Old 10-24-2013, 02:17 PM
03xk8's Avatar
Thank you. Things are never easy are they!
I haven't been on the forum in awhile my sincerest apologies to any & all who have replied to my post & not received an acknowledgement or thanks.
I hope to catch up & rectify tonight
Old 11-08-2013, 10:28 AM
03xk8's Avatar
Default SLCM matching
I'm confused regarding the Vin number
Since the suffix on the used module I have is AB if I purchase a 2610AB will I be okay?
My car is a 2003 but the used replacement SLCM is from a 2004 XK8.
The Vin # information they sent me with the part is:
SAJDA41B443A37325
Old 11-08-2013, 12:30 PM
Received 6,242 Likes on 5,443 Posts
Your VIN ends with - A37325
So according to Grahams info you need - from A30645 : LJE2610AC
Or you could do the flip key conversion, it seems any old X/S Type fob will work.
Any fob experts know why that is when the originals are so picky?
03xk8 (11-08-2013)
Old 11-08-2013, 03:57 PM
03xk8's Avatar
Default key fob/remote
So the AB suffix on the SCLM isn't relevant ?
Would the vin from my car have any bearing, or as long as the remote matches the used SCLM it'll work ?
You also mentioned keys, previously I was told that even though my keys are "old" they still contain a chip.
Will/Do I need to also replace my keys?
Old 11-08-2013, 05:35 PM
GGG is online now
I understood from your original question #1 that you were only looking for the correct remote fob.
Now it appears you have replaced the SCLM?
03xk8 (11-14-2013)
Old 11-09-2013, 12:38 PM
03xk8's Avatar
Sorry for any confusion, hope these specifics/car history will clarify.
My car (an 03) is a flood car I'm rebuilding. Apparently it's orientation at the time of the flood basically soaked the trunk(boot!). Water DID NOT get under the dash or into the engine. With the battery hooked up the dash,headlights,tail lights,windows all function. According to the seller if I replaced the SCLM which would require reprogramming I should be able to start the car. I only received the keys which made sense to me since the remote would need to match the new/replacement SCLM. The programmable SCLM I purchased is from a 2004 XK8.
Based on previous post I looked for the VCats sticker & it appears it was drowned along with the SCLM. I can't find or see it anywhere in the trunk.
Graham I believe serendipity has brought you to be my expert guide on a flood car. Could your first post be any more apropos !?! "I'll dip my toe in these very dangerous waters"
NCJagman
12-24-2015 05:13 PM
Jahnese Alston
US Northeast
09-20-2015 02:22 PM
Unhingd
09-19-2015 09:38 PM
kabs3012
09-12-2015 10:40 AM
kabs3012
US Midwest
09-10-2015 01:17 PM
Quick Reply: Searching for remote match
