XKR Brake Pad Question
Had the car in to the dealer today for oil change, warning light fix, and battery replacement. They also recommended brake fluid flush/replace at about $200 and rear brake pad replacement since they are at 3mm (parts $350 labor $160).
$350 seems steep for pads but the dealer said it was because these were Brembo.
I declined the brake servicing for now but was just wondering what others have done--bite the bullet and go with Brembo pads from the dealer or ?
Thanks,
Doug
Thanks,
Doug
Parts are a "profit center" for dealers, and Brembos are more expensive, but for just pads that is pretty steep. Your other options are to select a different brand, buy the parts on line and DIY, or find a reputable independent shop near by that will put the brand you want on.
My local Jag dealer recently offered to replace both rear shocks for $1140 (no thanks), so I went to a local indy shop and got it done for half the price.
Doug, I have the brake fluid in my 2005 XKR changed out every two years and about two months agao it cost me $90. As regards the brake pads, I would pass on the Brembos. I replaced the Brembo pads with Hawk high performance street pads and they have been excellent...very low light colored dust, no noise and very good stopping performance. And, the Hawk pads were much less expensive. When I changed out the pads and rotors I had the callipers thoroughly cleaned and was careful to breakin the new parts before spirited driving. That was about 10,000 miles ago and all is well.
Hope this info will be helpful.
Tim
Tim
You can pick up a full set of pads for about $150 from what I saw when I bought my ceramic Akebonos (which are street pads, little less bite, but zero dust and zero squeaks).
Parts are a large source of markups for dealers and local shops alike, so I usually get my parts online and do it myself, or find a shop that will use my parts.
You could also just do it yourself, once you take the wheels off its maybe 10 minutes per caliper to change the pads.
Arland Green (05-27-2014)
Thanks,
Doug
Thanks,
Doug
Tim
Tim
I agree with Tim on this one Doug. I went with the Hawk brake pads and installed them myself...and I'm an idiot!! Not a hard job in the slightest. Probably the hardest part was getting the wheel off!! (always use copper based grease between the wheel and the hub)
Danny
Question: I had the brake pads replace and rotors replaced on my XK8 (non-R).
Learned two things: 1. There were no low brake pad sensors, so you need to measure the pad wear periodically. 2. The rotors could not be resurfaced, because the metal was already worn below spec.
Hopefully these rotors will last, so next time I can just change the pads.
I would give it a shot once and see. Worse case, you get your hands dirty and can decide to go back to having the mechanic do it. Personally, before I did my pads I felt like its one of those things maybe better left to the mechanic, but once I did change the pads myself I realized how there's really not any room for error - once you have the caliper open (one or two bolts) you kind of notice the pads just either go in or don't, super easy. Then I just shook my head at not trying it earlier and saving all those labor costs . And besides, it's not even the few hundred in labor I save each time, as much as the fact I kind of enjoy working on the car.
Thanks for the replies. So it looks like Hawk pads are the ones to consider. Are these typically available in auto parts stores or easier to get on the web? And also, any problems with mixing manufacturers (Hawk pads with existing Brembo rotors)?
Doug
Doug
I would just google "brembo pad change" or similar. It's pretty intuitive. Quick search resulted in this link, which should give you a quick idea of the work involved.
http://g35driver.com/forums/brakes-s...embo-pads.html
And for your earlier question, for most applications, having a different brands of rotors and pads is fine, you'd just want to make sure you are consistent per axle (ie, right is not different then left, and same performance type pads in front and rear (ie: not ceramics in front, and race carbon pads in rear) ).
My 2003 XK8 has the best brakes i've ever had in a car, but it comes at a price (like everything else). I keep my car OEM. Just my opinion, but these are not the kind of cars people should "cheap out" on but, like i said, it's just my opinion ....
Before removing the calipers and starting the swap, I'd measure the thickness of your rotors...or ask a brake place to give you the 'free inspection' for that, save you some time if they are gettign thin. The xkr starts out with less 'meat' than our XK8 does. If its near or below min, i'd consider ordering new rotors while you're getting the pads. Easy to change while you've got your front apart for the pads...don't forget the copper grease betweenrotor and hub. You can still find Brembo rotors out there, for not much more than other good manufacturers, if you want the original.
