Anyone added a backup camera to thier factory system?
If so was curious what interface system they used?
I would like to try doing it myself but unsure which product I should use. I found one from NavTool but it doesnt seem very clear. |
This is something I am currently looking into doing on my 2001 XKR (same principle applies to the S-type). You need something like this:
http://www.nav.tv/category/7/68/128 http://www.nav.tv/files/imagecache/b.../NAV-INJAG.jpg To connect this up, you have to cut some of the wires behind the nav screen and wire this device in - you then connect your reversing camera to this device. I am guessing you can also fit this in the boot (trunk) of the car. Installation instructions here: http://www.nav.tv/files/navtv-technical/NAV-INJAG..pdf A bonus is you can then connect other video devices (like a DVD player) up to your sat nav screen. :) |
It is much easier to install the NavTv unit in the trunk.
Originally Posted by Jaxkr
(Post 252119)
NavTV
Originally Posted by dibbit
(Post 252088)
http://www.nav.tv/category/7/68/128 |
Pretty straight-forward doing the RGB in the center console... run the camera lead there, you can also do a front camera to protect the nose!
