ipod connection help
hi guys im new to the forum, i need a lil help., i just bought a 2003 jaguar stype, and the car has a cd changer in the trunck with no magazine, also in the middle concel it has a ipod connector,
my question is, wat button on the radio do i press to make the ipod work? the radio is a single cd with no cassette,. if any 1 can help pls.. thanx alot |
Not sure but try to put your radio / CD selector on CD and give it a try. If that does not work check and see if you have an on/off switch in the glove box.
thanx man ima try it right now see
Originally Posted by eloscarin1
(Post 250045)
my question is, wat button on the radio do i press to make the ipod work? the radio is a single cd with no cassette,. if any 1 can help pls.. thanx alot http://www.jimrothe.com/jaguar/acm-b...l#installation |
2008 X Type ipod Connection
Hi guys, I need help with connecting my new iPod Nano 16Gb into my 2008 (last edition) X Type and buying an ACM seems a costly solution, so I've been looking round for suitable alternatives. It looks as though my only route is with an FM modulator, which by all accounts is a lot better than a low cost transmitter. This involves tapping into the aerial connection behind the head unit (the aerial terminates here rather than in the back with the satnav) so it looks pretty straightforward. Looks like a DICE kit will do the job (it comes with an Ipod docking cable) but I need to power the DICE box. Anyone tried this and can help before I go ahead and purchase? Appreciate any help either across the pond in the US or here in the UK. Thanks guys!
| All times are GMT -5. The time now is 07:59 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
