Non-Alpine Stereo
Hey guys. I'm new to the forum and need some help.
I have an 03 xj8 sport. I would like to keep factory head unit in dash. But would like to install my infinty kappa amps and speakers. Does the factory system use an external amp that I need to by-pass? Or do I wire in line converters behind the head unit? Please help. Thank, |
1 Attachment(s)
yes, use of LOC will do the job but make sure there are no transformers inside, but just resistors. Or simply built your own like the one I attached. (left side is radio side, right side is external amp)
there is no common ground, and there shouldn't be a common ground on the inputs of your infinity amp either so everything is OK to go. |
