give away gearbox
give away gearbox
Hey,
I have a Automatic transmission from my series 1. works fine but i dont need it anymore.
I am happy for someone to take it, these old cars are getting harder to find and if possible i would like to help keep one on the road rather than throw out parts.
Located in brisbane.
Its in the for sale section for $100 and a high five, no bites there, thought i would offer it for free here first.
Received 6,317 Likes
Glenn, the numbers don't mean anything to me. Never had my trans out of the car.
I will get a couple of the guys to have a look at your picture.
Tomorrow I will look at the BW66's I have and see what numbers they have.
Edit, just had a look at the BW66's, the the pipes to cooler come out just below the ID tag on them so I'm guessing it is not a model 66.
I have sent Grant Francis & Doug a PM to have a look at your pics.
Originally Posted by Doug
Hopefully Grant knows...because I'm not sure
Originally Posted by Grant Francis
Clarke,
I see a vac modulator on it, which is BW12, but it appears on the RH side, and my memory???????, is the BW12 is on the LH rear corner just above the pan gasket flange, but I might be wrong.
Might be a BW8, but that is a pure guess.
If its a cast iron main case its a BW12 or similar, the 65/66 were alloy?, and NO vac modulator, using cable for kickdown.
Glenn, I have searched the numbers on the tag and all I can find is that it is Borg Warner, but can not find any mention of a BW12.
Looking at the pictures I have I suspect Grant is right, the model 8 has the shorter body and the model 12 is longer.
EDIT:
BW-8 from 1967-up. The BW-12 was used 1973-74
It all points toward it being a BW-8, in that case it is no use to me.
Thanks for the offer Glenn, I hope you find a home for it.
