Mytee Big BOSS Solution Sprayer now available at PinnacleWax.com
10 Attachment(s)
We Now Carry the Mytee Big BOSS Rechargeable Solution Sprayer on PinnacleWax.com
http://ep.yimg.com/ay/pinnaclewax/my...yer-6002-1.gif Portable battery-powered solution sprayer provides ultimate car cleaning versatility Say goodbye to the power cord and electrical outlet and say hello to the Mytee Big BOSS Rechargeable Solution Sprayer! This rugged, 5-gallon electric solution sprayer is designed for continuous heavy-duty use in all mobile detailing situations. With an on-board battery and universal intellicharger, the Mytee Big BOSS Rechargeable Solution Sprayer is the most advanced battery-powered solution sprayer available! https://www.jaguarforums.com/forum/a...ine=1388168618 The Mytee Big BOSS Rechargeable Solution Sprayer should be the first item on your list if you plan on starting your own mobile detailing business. Featuring a 5-gallon lift-off-tank, a 15 foot coiled solution hose and easy-grip storage basket plus the ability to clean with or without chemicals, the Mytee Big BOSS Rechargeable Solution Sprayer is one of the most versatile detailing tools available. https://www.jaguarforums.com/forum/a...ine=1388168618 The Mytee Big BOSS Rechargeable Solution Sprayer includes a Sidekick spray bottle as a standard feature. This bottle allows you to store additional chemicals on board. Switching to chemical cleaning is as easy as attaching a quick connect. With the extended lance spray jet, you can even clean carpet and upholstery with ease! https://www.jaguarforums.com/forum/a...ine=1388168618 One of the drawbacks of being a mobile detailer is the inability to rinse wheels, tires, and engine bays after using all purpose cleaners and degreasers. While hand pumps do the trick, they don’t provide enough pressure to blast the cleaner out of cracks and crevices. The Mytee Big BOSS Rechargeable Solution Sprayer is the answer you’ve been looking for! Now you can clean wheels, tires and engine bays with confidence! Warranty Limited lifetime warranty Body Roto-molded polyethylene Tank 5 gallon Pump Diaphragm PSI 60 GPM 1.2 Battery 10 AMP hour Volts 12 Spray per Charge 60 gallons Charger On-board Jet 8006 Wheels 8" Casters 3" dual front swivel Product Weight 43 lbs Product Dimension 20 1/2" x 13" x 37" Wipe Off https://www.jaguarforums.com/forum/a...ine=1388168618 That Was Too Easy! Took me less than 10 minutes to wash the car. I love this wash method :icon_headbang: https://www.jaguarforums.com/forum/a...ine=1388168618 GET YOUR Mytee Big BOSS Rechargeable Solution Sprayer at PinnacleWax.com |
