Low battery indication
Hi there
I keep getting a low battery indication on the dash even after a long run. It reaches a point where the rear won't open on its own, without manually lifting it open. My battery charger when connected to the battery only takes about 15 minutes before it indicates that the battery is fully charged. Any help/ideas would be very welcome! Many thanks Hinton4G |
Same here
I was told I need a new battery
Originally Posted by Hinton4G
(Post 2481247)
Hi there
Here in the states, any auto parts stores that sells car batteries can test your car's battery FREE of charge. I think your battery is showing that it is on it's way out. Have it check before you buy a new one. Also, check battery connections if loose or corroded. Tighten or clean battery cables & + - post. Good luck
Low Mileage?
2018 epace: my wife drives very few miles. She had her battery replaced under warranty December 2020. Basically lack of use no codes or unusual draws, loose wires, etc
Originally Posted by dagny747
(Post 2490877)
Normally I would, in fact I have one in my garage, along with a battery pack left over from my XJ6L. However, due to an accident and being in a wheelchair I can no longer do that. I do use the remote start and the app to keep track of her mileage to ensure the vehicle is running. Not optimal but it’s better than nothing. Now if I could drive it around the block remotely 😉
Hi Monkey 2018
Thanks for your reply. I thought the same as you as well. But I took it to a technician who connected what looked like a small laptop. He then re programmed the battery charge monitor. This made the car think it had a new battery, and all has been well since then. Fingers crossed !! A main dealer would be able to do the same. Regards |
Hi 2018XF25T
Thanks for your reply. A technician re programmed the battery condition monitor, and all has been ok since then. Regards |
Hi 1997XJ6L
Thanks for your reply. A technician re programmed the battery condition monition, and all has been ok since then. Regards |
| All times are GMT -5. The time now is 07:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
