E type ( XK-E ) 1961 - 1975
6.0 v12
Old Jan 27, 2012 | 10:28 AM
e21pilot's Avatar
Default 6.0 v12
I'm hoping the followers on this board can answer a quick question about engine swaps. I want to know if a 1994 6.0 V12 can fit in place of a 5.3 V12 in a 1972 E-Type? If so, am I correct that the original transmission would mate up or would an adapter be necessary.
Thanks,
Old Jan 27, 2012 | 04:42 PM
andy303's Avatar
I would think that the block is relatively the same, but I wonder about sufficient clearance under the bonnet for the EFI stuff.
These guys would know: V12 E-type EFI-conversion / AJ6 Engineering
Old Jan 30, 2012 | 04:45 PM
andy303's Avatar
Default v12 Swap
Check out this video:E-type mit 6,0 L Einspritzanlage , Motor , fuel injection, roar , sound - YouTube
It being done in Germany, but contact Roger Bywater at AJ Engineering at the link above.
Old Feb 3, 2012 | 02:43 PM
M90power's Avatar
it will fit fine, but i would keep those quad carb setups.
Old May 23, 2013 | 09:50 AM
jaguar jon02's Avatar
you will need to change all of the front to use the old jag parts 6.0 has one belt and the 5.3 has more
Old Aug 30, 2013 | 11:00 AM
Mr. Magic Plane Person's Avatar
Correct me if I'm wrong, but I don't believe the oil pan will clear as you'd hope. Iirc it's a few inches deeper
Old Sep 2, 2013 | 09:19 PM
calvindoesntknow's Avatar
you could flip the oil pans,
the block would need to be redrilled for the new block, in a few places which isn't really a big deal.
I agree with m90, id throw the carb setup and keep.the front pully system from the 6.0
workworkwork
Oct 1, 2015 01:44 AM
MattB731
Sep 30, 2015 10:37 AM
marklcap
Sep 29, 2015 12:41 PM
redgear
Sep 26, 2015 07:21 AM
