E type ( XK-E ) 1961 - 1975
E-type front license plate holder
Old May 16, 2020 | 09:08 AM
Christer Larsson's Avatar
Question E-type front license plate holder
Can anyone give me the total length of the rod, starting from the plate holder and finishing in the center of the "eye" on the front frame
(and stay avay from Covid19)
Old May 16, 2020 | 05:06 PM
DeusExMaxima's Avatar
I can get the measurement for you but I'm a little unclear what measurement you're looking for
Old May 17, 2020 | 03:15 AM
The total lenght from the hole in the license plate holder to the center of the attaching point on the subframe in front of the radiator
Old May 17, 2020 | 03:57 AM
Alos if someone has the correct pattern for drilling the holes in the front of the hood where the bracket on the plate holder is attached, I'd be pleased
Old May 18, 2020 | 05:25 AM
Coventry Foundation's Avatar
Christer it would help if you said which year your car is. Series one and series 2 cars are fixed differently.
Old May 18, 2020 | 09:41 AM
It's an early ser 1.5, made 67 and registred 68
Old May 20, 2020 | 05:52 AM
Then the holes will be horizontal to the front lip (but) there are two special packing pieces that go on the back of the lip to hold all straight. You will need access to the back side. The pan in the front bottom of the bonnet will need to be removed. The packing pieces are readily available. Series two (69-71) have different mounts on top of the lip FWIIW.
Old May 27, 2020 | 10:06 PM
RedRider48's Avatar
I just saw this post. Mine was built in early '67 and titled as a 67. It's series 1.5. with toggles and open headlights. Tomorrow, I'll check the rod length, as I have one on the shelf. I just need to find LOL!
Old May 28, 2020 | 08:55 AM
RedRider48's Avatar
Christer, here is the setup I have. The rod is 14". As you ca see, the clevis attachment makes it adjustable. Don't be mislead by the angle. It is 14" from the center of the "curved" end. Hope this helps. Apologies for the enormous size.
jagtoes
Aug 25, 2018 06:37 PM
luvinmyjagxf
Nov 20, 2017 10:00 AM
Quicktruck
Nov 19, 2015 05:32 PM
c3r3br0
Apr 30, 2011 05:54 PM
Disco stu55
May 3, 2009 11:27 AM
