Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   E type ( XK-E ) (https://www.jaguarforums.com/forum/e-type-xk-e-59/)
-   -   Engine number (https://www.jaguarforums.com/forum/e-type-xk-e-59/engine-number-249793/)
jaguar1966$ Aug 7, 2021 09:23 AM
Engine number
I have a 1966 Jaguar XKE with engine number C-27110FF cannot find our any information on date etc.
RM9700 Aug 7, 2021 10:04 AM
Hi, That is an unusual engine number. Anything is possible but I believe a '66 Series 1 should have an engine number starting with "7E". The number for your engine should be near the oil filter, on the block above the filter housing. And if you have the original data plate it should also be stamped there. Do you know the car number, that would also help track down model year and build dates.
cheers,
Richard
jaguar1966$ Aug 7, 2021 05:43 PM
cheers,
Richard
Dear Richard thank you for your response. I may have read the numbers wrong. I believe the heads were replaced before my ownership they read 7E53275-9. I have the Jaguar Heritage Trust document. Chassis number matches Build date December 21 1965. I dont know if this helps. Thank you Don Calabro
RM9700 Aug 8, 2021 09:42 AM
Hi Don,
The closest engine number to 7E53275 listed on the XKE.collectordata.com site is 7E53274-9. That is from a '67 4.2L 2+2 RHD, car number 1E50919BW. You can search on the site based on your car number to see if there is any data.
Richard
Coventry Foundation Aug 8, 2021 02:17 PM
Jaguar1966$ just fyi---part numbers that star with C XXXX are functional part numbers. BD is trim and such. The 'C' number you see is simply the part number for the block.
dibbyandco Aug 9, 2021 06:13 AM
The "9" at thr back of the number indicates it's a 9:1 compression ratio engine, i.e UK spec, so good news
jaguar1966$ Aug 9, 2021 09:18 AM
Thank you Richard for your followup I will continue to research it. Don
Tom65 Feb 10, 2023 04:20 AM
RHD, 1965 Series 1, 4.2 liter engine's number?
Hello brothers! Could you tell me please where/how to locate Jaguar e-type RHD, 1965 Series 1, 4.2 liter engine's number?
RM9700 Feb 10, 2023 09:20 AM
Unless modified or replaced, the engine number should be stamped in two locations: On cylinder block right-hand side on horizontal flange above where oil filter is fitted, and on cylinder head in vertical surface at the front of the central valley above the forward spark plug. Cheers Richard.
© 2026 MH Sub I, LLC dba Internet Brands
