E type ( XK-E ) 1961 - 1975
Oil relief hose
Old Oct 25, 2022 | 09:36 PM
pragmatic's Avatar
Default Oil relief hose
New owner here, of an XKE - I've owned an XJ8 for 5 or 6 years. I'm picking up my car next month. Reading up on maintenance issues it seems the hose from the oil filter housing to the pan is a failure point. I've also read that the two fittings are different sizes, filter end being 5/8 and pan side 1/2.
Has anyone changed the fitting on the oil filter housing so that its also 1/2 inch so a plain hose could be used? I'm guessing, based on British construction and parts catalogs showing an o-ring on the fitting that the fitting has British Parallel Threads (BPPT). Once I get the car I'll investigate making the change.
Old Oct 26, 2022 | 11:40 AM
Valerie Stabenow's Avatar
Default You may want to consider this:
Here's a place that has them:
perfectphoto
Dec 16, 2021 07:14 PM
jcvegasdog
Jul 27, 2017 08:18 PM
GoldCloverLeaf
Jul 13, 2017 10:25 PM
NtAFord
May 17, 2014 11:11 AM
Dan Bennett
Aug 5, 2013 04:59 PM
