E type ( XK-E ) 1961 - 1975
S3 Rear brake issue / rebuild
Old Apr 30, 2022 | 11:36 AM
MuswellJag's Avatar
Default S3 Rear brake issue / rebuild
Hi all and thanks for any advice
A couple of years back I had some work done on my S3 ( new handbrake cable and pads plus new main pads ) but upon using the car I noted the dreaded burning smell and was able to trace it to the nearside rear disc. I had assumed it was a binding handbrake pad followed shortly by no handbrake.
I have just spent a pleasant bank holliday removing the IRS with no ramp but have found the nearside main pads are binding slightly ( prob the cause of the heat ) and one set of handbrake pads ( offside ) had simply dropped out/off ( I found one pad on top of the housing with little wear ).
Sounds like a simple calliper rebuild and a new set of handbrake pads ( the main pads are new ). I am not sure why the handbrake pads have dropped out though any advice ?
It was some 25 years ago I last had the IRS out. Can I get the callipers off without removing the "cradle" by taking the hand brake callipers off ?
There seems to be plenty of info on earlier models on You Tube but can anyone point me to a specific video on the S3 ?
Simon
Old May 1, 2022 | 08:45 AM
clubairth1's Avatar
Community Influencer
I don't know what an S3 is? Sounds like an early model Jaguar?
Maybe post in the section for that model?
Old May 1, 2022 | 04:50 PM
Fraser Mitchell's Avatar
E-type Series 3, or XJ saloon Series 3 ?
Old May 3, 2022 | 04:18 AM
MuswellJag's Avatar
Apologies all
s3 e type !
Old May 3, 2022 | 09:26 AM
Originally Posted by MuswellJag
Apologies all
s3 e type !
Simon,
I've moved your question from General Tech Help to E-Type forum. Members here with the same model will be able to help.
Old May 8, 2022 | 09:39 AM
Dleit53's Avatar
I am reasonably sure you can remove the calipers by separating the handbrake caliper from the hydraulic calipers and removing them separately. It is tight. It has been a long time since I worked on an S3, I know it can be done on an XJS.
Dukejag
Oct 10, 2021 01:54 AM
MajorTom
Sep 16, 2021 10:27 AM
jagtoes
Mar 20, 2020 01:54 PM
Sonspit
Jul 11, 2014 08:52 AM
Ness925
Aug 29, 2013 09:42 AM
