stromberg 175 cd 2 throttle release valve
I'm not sure what part you mean by the throttle release valve. However, practically all parts, except for the actual carburetor body, are available as new parts. I have numerous Major Rebuild kits in stock; accordingly, if you can't get the required parts locally, I'll be able to help you.
Post a picture of the part you require so that there is no confusion.
Regards,
Brent
Hello Ol Blue,
Regards,
Brent
Regards,
Brent
Throttle bypass valve
Torn inside
Thanks brent
Please pm me what you have for major rebuild kits
Hello Ol Blue,
Attached is a picture of what you get in a Major Rebuild Kit. Virtually, you get all the parts to rebuild the carburetor, including butterfly shafts, butterfly disks and the bearing/seal for the shafts.
The kit shown in the picture is for a S3 E Type and has sufficient parts to rebuild the four carburetors. The parts shown in the picture are a bit hard to make out, being in sealed plastic bags, but the package in the lower left of the picture contains the diaphragm for the bypass valves. This is the part that you're referring to in your last Post. This diaphragm can be bought as a separate part, but unless your carburetors are in particularly good shape, I would do the full rebuild whilst the carburetors are off the car. I generally do a full rebuild on S3 E carburetors, as they are quite a job to remove.
If you care to PM me your email address I can send you pictures of all the individual parts and before/after pictures of carburetors I've rebuilt.
Regards,
Brent
Regards,
Brent
Hello Ol Blue,
Regards,
Brent
Regards,
Brent
Hello Ol Blue,
Regards,
Brent
Regards,
Brent
clubairth1
22
12-19-2022 07:08 PM
xjrjag
09-27-2015 01:53 AM
