dull headlights
Any products out there that really work on oxidized headlights?
RE: dull headlights
if the lens are plastic maguiers PLASTX IS GREAT. ABOUT $5 AT AUTOZONE OR PEP BOYS
RE: dull headlights
I have the same problem but I going today and trying out PLASTX, I let you guys know.
Thanks Man! ORIGINAL: 2004XJ8 if the lens are plastic maguiers PLASTX IS GREAT. ABOUT $5 AT AUTOZONE OR PEP BOYS |
RE: dull headlights
medium grit rubbing compound and a good buffer will do the trick
RE: dull headlights
Here is what worked for me... check post 36-38
https://www.jaguarforums.com/m_19784..._4/key_/tm.htm |
clear headlights
i was totally impressed with the resuults I got from the kit 3M offers. Lights look new and all you need is a drill and some painters tape. And the kit is only like $13 at autozone.
Here is a posting I put up that JIMC64 was kind enough to post for you all to see in the detailing section.......
https://www.jaguarforums.com/forum/s...ad.php?t=25265 Shows the proper proceedures for correcting headlight lenses using a pnuematic system with 3M products for a 6 step flawless restoration. Dave @ Innovative Detailing |
