Intake Manifold Polish
The next victim of boredom well depending what time I come back from watching the soccer game.
https://www.jaguarforums.com/forum/p...&pictureid=680 B4 pic |
Been thinking about doing this on the air to water intercoolers on my car.. How long did it take you? Did you hand sand them or did you use a belt/orbital sander?
Well I started with removing the rough surface with grinder, bad idea I had to work more because of this. Then I use a drill bit attachment on my power drill, had to be careful because if I angle it wrong the drill would hit the intake and scratch it I decided that the best way to go is to us a double wheel sander and small places a dremel. I still need some more sanding with fine grit sandpaper and some edge work but I think it looks better. I am also waiting for the supercharger plate being fabricated for my car I decided on a Vortech. I will keep you posted on another post about that.
You did some good job , glad you enjoyed your time ;)
If you don't want to do it yourself check these guys out the are awesome
www.mirrorfinishpolishing.com Thanks Cadillac |
