Tail light conversion
Ive got a MY99 xj8 that im repainting and basically restoring, since the rear quarter was replaced and now starting to rust under the tail light, i was wondering how different MY04+ tail lights are.
3 Attachment(s)
Hey Jaguarspeed,
I have looked up the images for the headlights. I have added some pictures from the taillights for you. First picture is a 2004 x350 taillight Second picture is a 99 xj8 taillight Third and last pictures is again a 2004 x350 taillight I have no reason to believe that they would fit easily in each others casing / mounting point. I hope this helps your question. :icon_smile: |
they are 2 different systems, forget it
Depends how far you want to go..... I have fitted XF lights into XKs.... At the end of he day you can fit almost anything if you put our mind to it
http://sphotos-e.ak.fbcdn.net/hphoto...400_n.jpg?dl=1 |
Someone has replaced my rear quarter and since then the seam sealer has cause terrible rust issues and since I'm in there doin a bunch of repairs I figured I'd do some custom work. I know it needs work to make them fit, I just was trying to figure out if I needed all new buckets or if they had a similar size I could modify the existing ones.
