Is the F Pace available in turbo ?
Hi guys,
im from the F Type forum. I saw a F Pace car today and on the rear it has the badge 3.5 t. What's with the letter T. Is it because it's a turbo motor? Why ? Why didn't they use a supercharger for this vehicle and i stead opted to go with a turbo setup. Can anyone please explain why Jaguar is now using a Turbo. Turbo kills the exhaust sounds. No good! Thank you. |
I am not sure why jaguar put the t on the back of the 3.0 supercharged 340 hp engines.(supercharging is a form of turbo charging?) I know for sure that for 2018 the 25t (2.0t 247hp) and later on in the year 30t(2.0t 300 hp) are both turbo 4. They have fixed it for 2018.
Jaguar has changed the way its badged newer vehicles now. The "R" on some vehicles doesn't mean supercharge V8 anymore. The gasoline ( Petrol ) Ingenium 4 cyl engines will be turbo, otherwise it'd be a dog, and not a cat.
Im not exactly sure what models are available with in the NAS market as I don't live in USA anymore, but here in NZ all the 4 cylinders are Turbo, both petrol and diesel. I know in Land Rover side, they have a twin turbo 4 cylinder available, I'm pretty sure this will also become available with the F-Pace, and new Velar due to launch. The badging is depicted by level of spec, not necessarily whats under the hood/bonnet. Stephen - Supercharge and Turbo are similar in that they are both power adders. However Turbo basically recycles the exhaust coming out, puts it through a intercooler, then pressurizes it back into the engine. Supercharging is using engine power ( driven off crankshaft ) to produce boost. Little bit different in how they react when driven. Turbos generally have some lag ( hesitation ) till turbos spool up creating boost, where as S/C's don't need to build boost. |
Originally Posted by JBzXJ40
(Post 1735631)
(Post 1735631)
(Post 1735631)
Im not exactly sure what models are available with in the NAS market as I don't live in USA anymore, but here in NZ all the 4 cylinders are Turbo, both petrol and diesel. I know in Land Rover side, they have a twin turbo 4 cylinder available, I'm pretty sure this will also become available with the F-Pace, and new Velar due to launch. The badging is depicted by level of spec, not necessarily whats under the hood/bonnet. Stephen - Supercharge and Turbo are similar in that they are both power adders. However Turbo basically recycles the exhaust coming out, puts it through a intercooler, then pressurizes it back into the engine. Supercharging is using engine power ( driven off crankshaft ) to produce boost. Little bit different in how they react when driven. Turbos generally have some lag ( hesitation ) till turbos spool up creating boost, where as S/C's don't need to build boost. 20d > 180hp 2.0 liter 4 cylinder turbo diesel 20t > 247hp Ingenium 2.0 liter turbo 4-cylinder gas 30t > 296hp Ingenium 2.0 liter turbo 4 cylinder gas 35t > 340hp 3.0 liter Supercharged 6 cylinder gas S > 380hp 3.0 liter Supercharged 6 cylinder gas Trim levels are: Base Premium Prestige R-Sport S Portfolio (upgraded Prestige) |
