Low Washer Squirters 2017
For those that find the non-adjustable windshield washer nozzles aimed at the very bottom of the windshield, there are replacement nozzles, from a Land Rover, they offer 3 adjustable eyeball type nozzles, WORK PERFECTLY!
Do you have a link? I hate the washer nozzles on my F Pace.
Low washer squirters -FIX
Took several months, Jag in NJ identified Land Rover P/N's T4A1150, T4A1149 are direct replacement, work great, have 3 adjustable eyeball sockets.
Thanks, I got to get that done.
Originally Posted by Dabitz
(Post 1837390)
Morris Jaguar said they can't duplicate the issue. So aggravated. This is a $5 piece. I'll probably order and change it myself.
Can't duplicate
My original nozzles squirted at the very bottom of the windshield, right at the bottom of the wiper blade stroke, non adjustable nozzles, so I took issue to Jag NA in New Jersey. They talked to my dealer, said all was OK. I pushed back saying it was a safety issue and mailed to Jag HQ in England. An engineer came up with the fix, it took my dealer an hour to install so should be fairly simple. You have "transfer" the heater from the originals. GOOD LUCK!
Thanks again.
Do you have a link?
Low Washer Squirters Fix
Read threads, not a recall or anything, I just kept pushing till I had a fix, part numbers for nozzles in previous thread.
