F-Pace (X761) / C-X17 2016 - Onwards
Software Update now WhatsApp doesn’t work!
Old Aug 7, 2024 | 02:09 PM
IanandNikki's Avatar
Default Software Update now WhatsApp doesn’t work!
Hi,
new here!
just did the software update on our 2022 F Pace 5th August and now cannot verbally send WhatsApp messages - just get told recipient doesn’t have WhatsApp enabled - but they do!
anyone else experiencing issues?
Old Aug 13, 2024 | 04:57 PM
Kevh3835's Avatar
Default Same issue, but have a fix, it’s a WhatsApp problem.
Hi
Had the same issue and posted on this forum about it.
its not a PIVI issue, its a WhatsApp update that took place on the same day as the PIVI update (5th Aug). So the fix is to check your version of WhatsApp and ensure its got the latest version which was updated today (13th Aug).
Took ages for me to work it out but if you tried starting a WhatsApp message away from your car just using Siri (which is what CarPlay uses), it’ll tell you the same thing, i.e “the contact does not have WhatsApp…..”
Anyway, there’s your fix.
Good luck.
Old Aug 13, 2024 | 05:03 PM
Kevh3835's Avatar
Hi
Good luck.
Old Feb 11, 2026 | 06:05 AM
Tienshrod's Avatar
I had the same issue and only got partial success by deleting the paired phone, rebooting the handset, then pairing again. Turning all message alerts off and on again helped a bit.
Old Feb 16, 2026 | 07:21 AM
Tienshrod's Avatar
I switched to the whatsapp api for a project where I needed steady messaging without surprise charges, and it made life easier because the setup was basically just a quick QR scan. It handled chatbots and media messages without me wrestling with extra configs, and the flat monthly rate kept the budget predictable. If you need something that won’t flake out under load, it’s been solid for me so far.
Old Feb 16, 2026 | 07:22 AM
Tienshrod's Avatar
It also gave me much better control over message delivery and automation compared to the standard app. Overall, it’s been a reliable solution, especially for projects where stability and consistency really matter.
Kevh3835
General Tech Help
Aug 13, 2024 04:51 PM
rorainey
Jan 5, 2022 05:27 PM
jtmav
XF (X260)
Jun 5, 2021 10:37 AM
BiggShooter
Aug 23, 2020 06:18 PM
Thomas Stires
XF (X260)
38
Aug 25, 2016 03:29 PM
