VelocityAP ECU Tuning for Jaguar F-Pace V6, V8, 2.0T
#41
That is, even if you flash back it is possible to detect that it was flashed. So if your engine needs major warranty work, and they look for signs of tuning so they can deny warranty - they will find them.
#42
#43
#44
I’ve been driving with the VAP tune and pulley for a week now. While I’m not wringing the engine’s neck as I’m still within break in mileage, the midrange power increase and throttle response is honestly even better than I had imagined beforehand. In fact, the shove in the back at 3000rpm is more of a surprise than the much talked about top end. The pulley really lowers the rpm range for the midrange. And the throttle response is so sharp now that I happily leave it in D rather than S. Before the tune, throttle response in D felt way too numb for me, and I always drove in S. I intend to make a few 0-60 videos shortly using a Passport G Timer. I’m honestly expecting 4.3-4.4 0-60 numbers.
No significant change in fuel consumption for me so far under normal non WOT driving conditions. The tune has honestly exceeded my expectations.
On a side note: removing both the engine cover and sound deadening liner under the hood, along with installing BMC air filters really makes the induction side of this engine roar above 4000rpm, while remaining as quiet as stock in normal driving.
#46
https://www.jaguarforums.com/forum/f...pulley-179588/
Now, things would have been easy and straightforward, but........ my oem pulley seemed to be a recently revised model and i had to have a 2mm shim made with centering hub (requiring the VAP pulley also to be machined slightly (pics included). Without the shim the first rib of the belt would run off the pulley.
Ive sent my oem pulley to Stuart days ago and he will probably advise shortly on the best way to deal with this pulley revision. I’m the first one who has encountered this, but the shim has worked perfectly and as mentioned earlier, the tune is simply above and beyond expectations ....
#49
The guys at my bodyshop were able to do this easily following this write up for an F Type:
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#52
#53
As of today my 2017 35T Prestige has done 2000km, nearly all of them with the VAP tune, pulley and BMC airfilters, as it was tuned on day 1.... As surprising as the performance increase was right out of the gate, it has only gotten better as the engine breaks in. The Jag drank both fuel and coolant at an alarming "pace" in the first 1500km or so, but has settled down nicely on 18mpg in mostly city driving, and is very capable of hitting the 23mpg highway number on longer trips.
Throttle response in Dynamic mode, in Drive, let alone Sport, is quite fierce. It might actually take some getting used too...and I love it. After driving turbo cars all my life this throttle response is truly an eye opener. As I've mentioned before, as surprising as the top end performance is, the increase in midrange power delivery, is even more so.
The pops and bangs from the exhaust (part of the VAP tune) on overrun from 4k rpm and above, have only gotten louder and angrier over time, as has the exhaust note in general.
I also appreciate the VERY noticeable increase in supercharger induction noise resulting from the combo of BMC airfilters, overdriven supercharger due to the pulley, and the removal of both the engine cover and the sound deadening hood liner.
All in all the tune continues to amaze and is way beyond what I expected beforehand.
(Yes my baby looks a tiny bit different than a stock Prestige...20mm wheel adapters and some paintwork..)
#54
Whitefpace (05-09-2018)
#55
#56
#57
You would then need to send Stuart@Velocityap.com an email with that "data page" picture and let him know the new client that will be acquiring your VTech unit.
FYI, the new client would be required to pay for the tune, minus the price of the unit ($250usd)..the tune itself cannot be transferred over to another vehicle.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
#60
Flexray came in "around" 17.5MY, so not all F-Pace's will work on this unit. To verify, the client can always send me an email with the ECU label picture and I can tell if it's flexray.
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
