200 vs 140 kPa coolant caps and overheating considerations
Old Feb 23, 2026 | 09:21 PM
JagCode3's Avatar
Default 200 vs 140 kPa coolant caps and overheating considerations
I would like to revisit the coolant cap/pressure debate from a while ago as I am not sure a resolution was reached.
https://www.jaguarforums.com/forum/f...2/#post2634061
The 140 kPa cap (20 PSI) allows the boiling point of a 50:50 coolant/water mixture to go to 239 F before steam is released into the engine bay. The 140 kPa was the standard cap on most other Jaguar models of the recent past.
The regular operating temperature of the F-Type can range from 180 – 230 F during normal driving (not racing).
The 200 kPa cap (29 PSI) allows the boiling point of a 50:50 coolant/water mixture to go to 260 F before steam is released in the engine bay.
Could the overheating leading to the warped heads and complete engine loss be a result of the extra pressure of the 200 kPa cap allowing the temperature to rise to 260 F before the driver is aware?
The temperature bar gauge has time and time again failed to give adequate early warning on overheating. Do we know what specific temperature will set off the alert? By the time an alert is raised and the driver can safely pull over to shut the engine down, the damage has been done.
This is why I never drive without Torque Pro running real time coolant temperature onscreen and an obnoxious audible alarm set at 230 F that overrides music or telephone calls in progress.
I do use the 140 kPa cap.
Old Feb 23, 2026 | 09:26 PM
OzXFR's Avatar
I switched to a 140 kPa cap a few years ago and zero problems so far.
I did so purely as preventative maintenance seeing as my F-Type still has the original crappy seamed coolant pipes.
I keep the OEM 200 kPa cap in the boot/trunk as an emergency back up.
Old Feb 24, 2026 | 12:09 AM
sov211's Avatar
When I asked my Jaguar dealer to provide a new OEM radiator cap for the F-Type, the one they supplied was the 140 kPa, not the original 200 kPa unit. And like OzXfR, I have had zero issues with the lower pressure cap in place.
Old Feb 24, 2026 | 03:53 AM
DMeister's Avatar
Hmmm. That I do find interesting. Did they offer an explanation for why they did that? Just curious.
Old Feb 24, 2026 | 04:40 AM
DMeister's Avatar
I have no experience with this Torque Pro. Are there any battery draining disconnect issues going on for you with that setup that you have?
Old Feb 24, 2026 | 06:17 AM
JagCode3's Avatar
Torque Pro is an OBD2 reader program for Android phones and tablets, unfortunately not for iOS.
Yes you have to be aware of the OBD2 disconnect and battery drain issue. I have a physical switch for my OBD2 scanner.
This is discussed in this thread.:
https://www.jaguarforums.com/forum/f...4/#post2765724
This issue is different for different years of F-Types and updated programming of the ECU by the dealer. I have never had it happen in my 2019.
@sov211 thank you for bringing this issue up years ago...
Old Feb 24, 2026 | 11:07 AM
sov211's Avatar
No, no explanation given. The 140 kPa cap was one of the items my dealer provided for fitting of the metal coolant pipes, change of supercharger oil etc. Everything properly installed, no issues of any kind (but this dealer, Jaguar Land Rover Victoria has always provided excellent service for my Jags over decades).
quattrofrank
Dec 28, 2024 08:20 AM
Caughell
Mar 24, 2022 03:08 PM
mojorising
Nov 29, 2021 09:49 AM
mpasiuk
Aug 13, 2021 10:19 PM
scardini1
Dec 3, 2014 09:10 PM
