2018 F-type Apple carplay options (NOT BOSCH NOR HARMON)
Old May 19, 2026 | 01:10 PM
Rianf1's Avatar
Default 2018 F-type Apple carplay options (NOT BOSCH NOR HARMON)
Good afternoon all. My name is Rian. I have a 2018 Jaguar F-type and it is my favorite car I have ever owned. In my opinion, its only drawback is the infotainment system, more specifically, the lack on apple carplay. Now, I did some research on the matter and most people on the forums have went with some sort of piggyback add-on unit that fits to either a Bosch or Harmon head unit. My car being an 18' with the updated screen graphics, I thought that it was a Harmon unit. So I ordered a Harmon Carplay receiver. Much to my surprise, when I pulled the rear console cover off of my F-type coupe to inspect, I found that head unit does not look like a Bosch nor Harmon. Upon further investigation there was a small "switchover "window that where some cars received a newer headunit but with the crappy, older/smaller screen. I understand that the 2019 cars got a larger screen with Apple Carplay capabilities.
So here's where things get dicey. From what I have researched, my car is eligible the OEM larger screen and it will work with the current electronics but it is not as "plug and play" as it sounds. Apparently, in order for the screen to be swapped, some trimming needs to happen to fit as well as a new bracket, bezel and upper aluminum trim piece that works with the larger 10.2 inch screen. Not to mention, once the screen is installed, then it has to be programmed by JLR to the newer graphics. I really would prefer NOT to go down the route of the newer screen as I do not want to cut, trim and program. Is there any other method that will work for the "NON BOSCH/ HARMON" (later INTOUCH pro) radio that I do not have to jump through those hoops. Hell, I wouldnt mind one of those android screen units if it would work with my current head unit. I would really appreciate the help yall. Im at my wits end here. Below is a picture of the radio and screen.
Old May 19, 2026 | 02:33 PM
J444G's Avatar
It is spelled HarmAn Such as Harman/Kardon. You have IMC system. You are really in the (un)lucky year. I don't think I have ever seen a aftermarket unit for this, on the other side, you can go OEM and that is the best way.
More on this https://www.jaguarforums.com/forum/f...2017-a-246306/
Old May 19, 2026 | 04:39 PM
MajorTom's Avatar
There have been aftermarket units for the IMC system for ages and it's explained in a number of threads on here if you search. UAD provide this unit. I have it and it works brilliantly.
https://unique-ad.co.uk/product/wire...ype-2017-2018/
Old May 19, 2026 | 10:43 PM
Tech_JLR's Avatar
@Rianf1
I suggest to go with the oem 10" upgrade, its alot cleaner, just my opion. Ive done alot of these conversions, its not alot of work.
I've seen the aftermarket units cause canbus issues on the MS-CAN.
If you decide to go the oem route, i can help you.
Old May 20, 2026 | 06:13 AM
Rianf1's Avatar
Good morning @Tech_JLR and thank you for your response. I would like to go with the OEM 10" screen however, the issue is sourcing the programming. In the UK, there seem to be a plethora of outfits that are able to program the new screen to the head unit. I am in Atlanta, Georgia US and I dont know of any outfits here to do so. I believe across the pond, there is JLR Retrofits of which actually come to your location to perform the swap. Here, I attempted to go to my dealer yesterday to see if they can do it and they looked at me like I had two heads. Additionally, isn't there some cutting and trimming that needs to happen to get the new screen to fit?
Old May 21, 2026 | 05:28 AM
Tech_JLR's Avatar
Good morning. PM me your vin number. Let me check the vin and if its possible maybe youll make the dealer look like they have two heads.
marcofromtrubulya
Jan 1, 2026 02:46 PM
Pupilbone
May 18, 2024 08:41 AM
PowertotheV8
Feb 26, 2024 06:34 AM
rrstl3
Mar 28, 2023 03:19 PM
Blacks18
May 10, 2022 03:48 PM
