5w30 oil!!!
hi guys can i use 5w30 to my jaguar ftype r v8 AWD or i have to use the recommended one w20???? |
Originally Posted by mohammed m
(Post 2036175)
Recommended is 0W20 but 5W20 is perfectly OK and is arguably better than 0W20 in a hot climate.
But 5W30 is a big NO in the F-Type V8 or V6 engine. |
You can look in your manual maybe and see if there are other weights that are approved
Just finished an oil change in my 15 R. Oil weight plays a big role with clearances etc. I myself at first thought the oil is really thin for a performance car like this. But bearing clearances etc was set with this type oil weight in mind. So I usually don't mess with what the factory recommends.
Originally Posted by Terrance39
(Post 2039291)
This has to be a wind up!
1 Attachment(s)
RTFM
Originally Posted by Cambo
(Post 2039571)
RTFM
Originally Posted by Unhingd
(Post 2039602)
Unfortunately, that won't stop the discussion about heavier viscosities.
(Post 2039571)
RTFM
For those who haven't read it, it replaces our beloved Castrol EDGE Pro with Castrol Edge Pro C5, except for the AJ126 in cold climates... Castrol EDGE Professional E C5 0W-20, which has been jointly developed with Jaguar Land Rover, improves fuel efficiency and reduces CO2 emissions* while maintaining the reduction in metal to metal friction and wear. The Castrol EDGE Professional range is the only engine oil recommended by Jaguar Land Rover. * In tests versus Castrol Edge Professional E 0W-20 |
Originally Posted by DJS
(Post 2039666)
Nice doc, thanks. Says it doesn't apply to US/Canada, but I assume that's because they're not selling Magic Elixir #2 here yet.
For those who haven't read it, it replaces our beloved Castrol EDGE Pro with Castrol Edge Pro C5, except for the AJ126 in cold climates... |
