Aluminum Cooling Pipes - Finally!!
Old Feb 8, 2025 | 09:11 AM
  #601
JagCode3's Avatar
@Gasman2 My comment was not about country of origin but about parts labelled as "OEM" when they are clearly not. This is a serious issue when ordering Bosch fuel injectors and NGK spark plugs.
Also I am trying to avoid what happened to @WayneB although I note that these kits are sold out anyway.
https://www.jaguarforums.com/forum/f...9/#post2806561
Old Feb 8, 2025 | 11:18 AM
  #602
J444G's Avatar
@jahummer have you installed them yet? Do you have F-type or XKR from from your signature?
Old Feb 8, 2025 | 12:07 PM
  #603
clubairth1's Avatar
Community Influencer
Can anyone post what the JLR Aluminum pipes sell for?
Old Feb 8, 2025 | 12:29 PM
  #604
jahummer's Avatar
The US retail for the Y is around $83 and the upper’s around $205
Old Feb 8, 2025 | 12:30 PM
  #605
clubairth1's Avatar
Thank you jahummer!
Higher than aftermarket but not too extreme for what you get.
Old Feb 8, 2025 | 12:33 PM
  #606
jahummer's Avatar
This set’s going in a SCV6 Disco this weekend. I’ve multiple JLR vehicles.
Old Feb 8, 2025 | 07:03 PM
  #607
jahummer's Avatar
Y installed quite nicely, snug and perfectly seated flush and aligned. Note the diameter of the inlet's significantly larger than either the KO alloy versions or the genuine plastic versions making access to the notorious RH screw a bit more difficult in this state. Will note if there's any affect to accessing this screw with the supercharger in place.
Old Feb 9, 2025 | 12:44 PM
  #608
gearFX's Avatar
Pardon my confusion. JLR originally made metal pipes, then replaced with plastic with seams that failed. Then they revised the plastic part to address the seams but they are still brittle plastic. And now they are back to metal again? Are these the original metal design or some new version 2.0? I guess I'm asking: Have we just come full circle (and JLR is producing the old metal pipes again) or is this a constant evolution where each part is superior to the part that came before it?
Old Feb 9, 2025 | 01:12 PM
  #609
jahummer's Avatar
That’s correct! And they’re a completely new design.
What’s most puzzling to me is why for an engine no longer made or used???
Old Feb 10, 2025 | 03:18 AM
  #610
MaxD's Avatar
Lower cost than the very first iteration from EuroAMP - at least for those of us not in the US (subject to customs and high delivery).
LR186859 - £140
LR186917 - £57
Remember parts are designed & costed for manufacture well in advance of any changes to Company plans.
Old Feb 10, 2025 | 07:04 AM
  #611
gearFX's Avatar
Thank you! And just to clarify further, there are new JLR aluminum pipes for both the V8 and V6 engines?
Old Feb 10, 2025 | 08:40 AM
  #612
JagCode3's Avatar
@jahummer Any reason not to also pull the oil cooler to inspect it and replace the gasket while you are in there? Check out this post by @f-driver :
https://www.jaguarforums.com/forum/f...4/#post2691535
Old Feb 10, 2025 | 09:06 AM
  #613
jahummer's Avatar
Yes to both.
Old Feb 10, 2025 | 09:07 AM
  #614
jahummer's Avatar
Did mine last year but if it’s time to be done then certainly
added to the list of “whilst in there”.
Old Feb 10, 2025 | 10:01 AM
  #615
clubairth1's Avatar
While I love the fact that Jaguar did release these in Aluminum. Just think how much money they could have saved in warranty costs AND the big hit to their reputation because of the exploding plastic pipes. Just seems like a day late and a dollar short to me. This should have happened 12-15 years ago when the plastic cooling parts started failing massively.
I mean did they just now (2024) realize how bad these were? They had years of repair reports and complaints.
Old Feb 10, 2025 | 11:24 AM
  #616
jahummer's Avatar
it’s all quite strange, especially considering these engines have been discontinued. Main dealer did indicate these are intended as aftermarket parts And they still offer the plastic versions. But considering how JLR have been known to discontinue parts for models making serviceability, challenging, why would they do this?
Old Feb 10, 2025 | 04:37 PM
  #617
DMeister's Avatar
Oh wow, interesting…I was not aware that there were actual Jag metal parts for this stuff…
I have the revised plastic stuff on mine, but still, good to know…
Old Feb 12, 2025 | 03:15 PM
  #618
Robtrt8's Avatar
Ordered factory metal pipes through my dealer. He said they we're coming out of Memphis. My '16 F Type has 92,000 miles on original pipes.
Old Feb 19, 2025 | 09:03 AM
  #619
silvertonesx24's Avatar
I'm doing a timing job so the supercharger is out. I've had the Euro Amp parts for almost 2 years now and finally will be doing this. I also have the new aluminum crossover pipe in hand
Is it still the consensus that the O rings need to be replaced with thicker ones on the Euro Amp stuff?
Old Feb 19, 2025 | 09:05 AM
  #620
Originally Posted by WayneB
A quick follow up, Euro AMP did give me a partial refund for the leaking Y Pipe and cost of the new Y Pipe that I had to buy but , that did not come close to covering cost of the additional man hours to find and replace their leaking Y Pipe. And as CarBuff2 says make sure you do a pressure test any time you do cooling system work, BEFORE you but the supercharger back on, I am so glad I had my trusted shop doing this work instead of me because I don't have a pressure testing kit and I would have just resembled the everything, only to fine the leak later and then I would have been REALLY PISSED.
How do you pressure test the system without the supercharger in place considering that coolant lines run into the supercharger?
