Battery Brace Flange Bolt Size
2018 F-Type Convertible. The battery in the trunk has a metal brace that goes across the center to keep it from moving around. It is held down by a single 10mm flange bolt that bolts to the back of the trunk compartment. Does anyone know what size (thread pitch) flange bolt that is? It's got a 10mm head--I think it might be an M6 but I'm not sure. The positive post auxiliary blade uses the same size.
Originally Posted by Thunder Dump
(Post 2278266)
Originally Posted by Unhingd
(Post 2280688)
No, it’s an M8.
(Post 2280721)
Correct, thank you. I figured that out a couple days ago (see the battery tender thread) but forgot to post an update in this thread.
