Break Dust
Break Dust
Does anyone know if it is normal to have a large amount of break dust on front rims? After I wash my car and clean the rims, within a week there is a fine layer of break dust on my rims. Within 2 weeks, the entire rims are covered in a fairly thick layer of dark gray break dust. Is this normal or do I have an issue with my breaks? My breaks work properly but I do have a slight squeak in the front breaks.
Thanks,
Thanks,
Thanks,
Thanks,
When? I'm 14 months in and the dust is still insane. I have to clean them after a ten mile drive.
(And I'm too cheap to change the pads before I need to.)
I use a 1 1/2 inch sash paint brush to dust them off between washings--only takes a couple minutes and the sash style gets into the corners.
I recommend Sonax as a wheel cleaner, followed by an application of Pinnacle makes a "Diamond Wheel Coating" spray that will slow down the build-up. Even a little regular wax will help. I'm 5 years in and can see some improvement over time. Brake dust is now only the second most likely thing to prompt a wash (#1 being the exhaust tips; I'm always in Dynamic mode.)
DuhCar (06-21-2019)
The pads dust the wheels so badly that a friend with a BMW commented, and I've long considered them the benchmark for "too much brake dust." When I'd wash the whells I'd always think "Oh, yeah. THAT's what color they are!"
Much better with the Porterfields. My only gripe with the Porterfields is the poor pedal feel in heavy rain. When the brakes are cold and very wet, the pedal effort goes way up and the feel goes down.
Received 3,114 Likes
I don't mind the lack of feel of the Porterfields in the (very) wet as that is maybe once or twice a year for me, at all other times they are great and they are well worth the dust reduction alone.
I installed low-dust Semi Metallic Centric Posi-Quiet pads when I lowered the car. HUGE difference in the dust build-up.
Another reason I can't stand brake dust is that it gets in the wash mitt when you wash the wheels. I use different mitts on the wheels as compared to the body, but brake dust is nasty.
That stuff HAS to scratch the paint on the wheels when washing them. Microscopically, certainly, but scratches none the less.
Yeah. You'll note that I did not say I swapped the back. I'll consider EBC next time, but have not made a decision.
I installed low-dust Semi Metallic Posi-Centric pads when I lowered the car. HUGE difference in the dust build-up.
I used two different sets of them on my old XFR (same brakes as the F-Type "super performance") for a year or so, and yes they were lower dust than the OEM pads.
But IMHO only about 1/3 to 1/2 the dust of OEM whereas I find the Porterfields to be 1/4 or less of the OEM. The Porterfields are also quieter and more progressive than the PosiQuiets, I suggest you give them a try next time.
Tork Monster (06-18-2019)
Agreed, the standard brake pads produce loads of dust, the front ones seem to produce more than the rear. It spoils looks of silver standard wheels.
I would love an effective way to make the
wheels easier to clean and keep clean, possibly some coating or wax might make the dust easier to remove.
I just had replacement brake pads all round and had genuine Jaguar pads fitted as I didn't wish to alter braking performance and feel.
That's interesting. I have zero soot on my exhaust tips, in fact, I've been amazed at how clean they've stayed and rarely even have to wash them. Maybe I'm not driving my car hard enough...
If the car is backfiring, as it should under specific conditions (snap, crackle, pop), you should be experiencing a lot of sooting.
