Center console cover - passenger side
Old May 16, 2026 | 08:55 AM
Kuhli's Avatar
Default Center console cover - passenger side
Hi everyone,
Does anyone know if the cover can be removed?
I'd like to remove the soft-touch coating and not do it in the car.
Regards, Frank
Old May 17, 2026 | 09:55 AM
Kuhli's Avatar
So, that sticky stuff is off.:-)
I used "WypAll Green Cleaning Wipes" and "Dr. Schumacher Orange Solvent."
The cleaning wipes alone would certainly have been sufficient, though.
They must contain a solvent that works effectively against the soft-touch coating.
By repeatedly wiping over the surface and using a plastic wedge I was able to lift off the sticky layer.
As you can see in the photo of the power window switch panel, the soft-touch layer can be neatly pushed together and lifted off using the wedge.
Old May 19, 2026 | 04:58 PM
zochmenos's Avatar
Looks good! For future reference, that small trim piece is held in by four clips. Disconnect by prying the bottom edge away horizontally from the pillar/grab handle toward the shifter. Work your way up to release all four. Snap back in evenly to reassemble.
Old May 20, 2026 | 12:06 AM
Kuhli's Avatar
Hello, I suspected as much.I didn't want to damage anything, so I didn't dare try.
Is it also easy to remove the air vents on the left and right sides of the cockpit?
Frank
Old May 20, 2026 | 09:32 AM
zochmenos's Avatar
This one I haven't had off but I would suspect the clips are similar.
Old May 20, 2026 | 12:02 PM
RoverJoe's Avatar
Community Influencer
Not as easy, but just a few bolts to get those out.
File Type: pdf
jnnt29
Jul 13, 2023 10:20 AM
BrentGuinn
E type ( XK-E )
Jan 4, 2023 12:27 PM
mcook
Oct 5, 2018 01:38 PM
XJL
Nov 30, 2012 03:32 PM
greased_pig
XJ40 ( XJ81 )
Jun 22, 2007 01:10 PM
