Ceramic brakes- Squeaking Noise
Hi Guys ,
Got 12K miles on my Ftype 400 with ceramic brakes and lately the squeaking noice has been unbearable!! Anybody here that similar experience? Or any advice here before I call service department ? thanks |
This is the problem with ceramic brakes. They do that. If yours is doing it way too much then I don’t know but a simple way to try solving it is hammering the brakes a few times.
Originally Posted by vika01
(Post 2082962)
Mine started at 16K. If I wash the car they are good for some time. I also give the brakes a good rip once in a while. It will go away.
A bit of noise is a small price to pay for no dust! ;)
don't hammer your brakes.. if you chip the rotors then say goodbye to 10k
edit: i thought he meant hammering with an actual hammer |
Originally Posted by Holy F type
(Post 2083127)
(Post 2083127)
Originally Posted by mv007F
(Post 2082940)
Hi Guys ,
Got 12K miles on my Ftype 400 with ceramic brakes and lately the squeaking noice has been unbearable!! Anybody here that similar experience? Or any advice here before I call service department ? thanks https://www.jaguarforums.com/forum/f...-miles-157813/ There's a TSB on this issue. https://jlr.oemdtc.com/TSB/SB-10065182-6903.pdf |
Originally Posted by bb_sam
(Post 2083336)
Had the same issue -- check out this thread:
https://www.jaguarforums.com/forum/f...-miles-157813/ There's a TSB on this issue. https://jlr.oemdtc.com/TSB/SB-10065182-6903.pdf Also that TSB makes no sense at all, it first of all says "Squeal noise from rear brakes - 380mm brake discs" when the rear "super performance" (iron) brakes are 376 mm not 380 mm (the front "super performance" and "high performance" brake discs are 380 mm) while the rear CCM brake discs are 395 mm (IIRC), then it says "with: high performance brakes" when the rear "high performance" brakes are 326 mm. In summary that TSB not only has nothing to do with CCM brakes it is a complete dog's breakfast! |
Originally Posted by OzXFR
(Post 2083337)
Do you have the CCM brakes?
Originally Posted by Unhingd
(Post 2083362)
It probably doesn't matter what that TSB actually applies to. Those are the same steps one would use to resolve the squeaking brake issue on any car.
