View Poll Results: How does your clutch work on maximum acceleration during a 1st to 2nd gear upshift.
Voters: 57. You may not vote on this poll
Clutch Satisfaction
#421
#422
Was in my transmission. After seeing oil analysis dealer flushed it and refilled with FFL-3 after they re-ordered fluid. Even before I run numbers of Pentosin that I got elsewhere. It was also service manager that suggested I run oil analysis in the first place and was willing to pay for it.
All past invoices state T2R17199 was used. I also recall them special-ordering this fluid from UK around 2016, since it wasn't in stock anywhere. So it is human error of some kind - either mechanic didn't use correct fluid despite having it in stock, or T2R17199 wasn't always FFL-3.
It would be interesting if someone could trace what was T2R17199 historically. Was that always this fluid, or perhaps there was a parts catalog error?
#423
#424
#425
#426
Last Production Date for 1st Generation Clutch
I bought my CPO car last July (2018) with 17K miles and put on another 7.5K miles last year before it going into storage for the winter. During that time, I never felt the clutch slip or smelled the disk burning and while I don't generally drive aggressively I have gotten on it enough to know that 2nd and 3rd gears are just beastly in the car. That being said, I don't want to have a bad surprise some day and be stuck in the middle of nowhere with an demolished clutch and would like to get the whole thing sorted out if possible.
Any commentary and/or direction is appreciated, thanks.
#427
rbsj (02-16-2019)
#428
Yikes, that's not good, it sounded as if you were having better luck with Gen 2 than that. Have others had equally bad experiences with Gen 2?
Still, I guess my question still stands. Has anyone, including JLR, identified when they stopped equipping our MT F Types with the first generation Volvo clutch? Production date or VIN #? From the one article that was posted to this thread, it appears the Jaguar engineers were well aware of the inadequacy of the first generation clutch by May 2015. Not knowing what's in my car is a little disturbing and if I have the first generation clutch then I would like to get the whole thing sorted out and get whatever generation clutch JLR is using currently installed in my car before the warranty runs out.
#429
I have a 2016 MY with vin 32135 - late 2015 - December delivery date - and the clutch works fine - no slippage whatsoever. It does have a slight vibration coming through the stick at 2500 RPM or so but is not consistent, has always had it and not getting any worse. I had a conversion with the dealer and they keep saying it is fine, but feel free to blow out the clutch and they'll replace it. Terrible answer and attitude but typical of jaguar.
rbsj (02-16-2019)
#430
All kidding aside, does it make sense that I could have 23K miles on the car and not have any indication of a problematic clutch to this point if I had the generation 1 Volvo clutch?
#431
OK then, it appears to be clear as to what my mission should be before the warranty period passes.
rbsj (02-17-2019)
#432
If shifting from 1st to second under hard acceleration doesn't induce slippage, you may not have the gen 1 clutch, but if you don't, you almost certainly have the gen 2 clutch which has a tendency to suffer from immediate failure without warning (can't be disengaged). However, at 23k miles, your clutch has already beat the odds.
If I do have the second generations clutch assembly in my car (seems likely) then from these messages it seems that JLR started installing the second generation clutches sometime between mbelanger's VIN #303xx w/ production date 9/15 and my VIN #318xx w/ production date 10/15. Hmmm... that is a full 5 months after the May 2015 article posted to this thread where JLR engineers were aware of the inadequacy of the first generation clutch assembly. Not overly inspiring craftsmanship/engineering on the part of JLR.
#433
This is pretty much what I had surmised as well, but I didn't know that the second generation clutch assembly was experiencing significant problems too.
#434
OK thanks, do let us know how things progress with generation 4. For those of us who plan on keeping and driving the cars it seems inevitable that we will all have a similar experience sometime down the road. Just hope it happens while still under warranty.
#435
#437
I guess its time to figure out how my Jaguar roadside assistance button works.
#438
I don't know what to make of this. I guess they were using up all the JLR parts until they ran out, then they bought some Volvo stuff hoping for a temporary fix until they could get the second generation parts going into production in 10/15?
rbsj (03-18-2019)
#439
Get this - I haven't even gone through a full tank of fuel in mine and it's currently in the shop for the second time inside of two weeks for transmission issues.
Bill400 (07-31-2021)
#440
I've used the roadside assistance twice, but my vehicle was home both times and had a a driveability issue. 90 minute guareeteed pick, but both times was less than an hour. Interesting is your car needs to be on flatbed, they will also flatbed it home after fixed. At least here in my area.
