disconect start /stop
Old Jun 28, 2022 | 05:07 PM
santacruz11's Avatar
Default disconect start /stop
how do i disconcet my start/stop on a 2016 f type r
Old Jun 28, 2022 | 06:08 PM
RGPV6S's Avatar
Use the search function there are many threads on this subject.
Old Jun 28, 2022 | 07:25 PM
tried that no luck thanks for the idea
Old Jun 28, 2022 | 08:15 PM
Roost5o's Avatar
I have seen threads for the 14-15s and it involved simply pulling a plug. I do not have such a plug on my 16 so I am open to ideas myself
i had this feature on my Denali and bought an auto stop eliminator. Installed the harness after removing a significant part of the dash/console. Well worth it to me though. Sadly I do not see that available for our cars.
Old Jun 28, 2022 | 08:20 PM
OzXFR's Avatar
Sorry, other way around.
On the 14-15 with the dual battery set up you disconnect the earth/ground lead from the negative terminal of the secondary/small battery from where it bolts to the floor of the trunk/boot, on the 16 and up (single battery only) you pull a plug in the trunk/boot, there is a thread showing exactly which plug and where somewhere around here.
Edit - found it: https://www.jaguarforums.com/forum/f...attery-146010/
Old Jun 28, 2022 | 08:35 PM
Roost5o's Avatar
Well damn Oz I got that twisted. Thanks. Must have been too much Bud Light that day. I just swore I did not see that harness then but I will certainly check again.
Old Jun 29, 2022 | 06:13 AM
powerhouse's Avatar
I’ve mine disconnected few months now with no issues or dash lights. The orange light on stop/start button stays on though
Old Jun 29, 2022 | 06:57 AM
skizot's Avatar
if you decide to tune the car through VAP, they can disable this as part of the tune as well. No dash lights.
Old Jun 29, 2022 | 07:24 AM
Carbuff2's Avatar
Doesn't help the OP with the coupe, but I understand the SmartTop accessory controls can let you disable the S/S as well.
https://smarttop.uk/
Old Jun 29, 2022 | 02:28 PM
Michael211's Avatar
The first entry in the post above worked perfectly for my 2017 S Coupe. No lights, no alterations, easy to reverse.
Old Jul 1, 2022 | 07:04 PM
how did u disconnect it??? thanks
Old Jul 1, 2022 | 07:09 PM
Roost5o's Avatar
Press the release and pull the plug is all. I did it after overlooking it prior. I have not tested it yet but I’m sure it works based on all the input I saw.
Old Jul 2, 2022 | 12:10 PM
Michael211's Avatar
As I recall I had to look very closely at the plug to find the release, and I seem to recall using some needle nose pliers. Once you get the release right the plug comes of easily.
Old Jul 2, 2022 | 02:03 PM
where is the plug located
Old Jul 2, 2022 | 06:58 PM
Michael211's Avatar
1. Remove battery liner in rear boot.
2. Remove boot (trunk) liner
3. Locate control module bottom right hand side - as you look in the boot
4. Remove the below plug and secure back with a Ty-wrap
Old Jul 3, 2022 | 09:27 AM
much thanks !!!!!
Old Jul 3, 2022 | 12:28 PM
thanks got it ez job and found some extra storage space !!!
Old May 16, 2023 | 07:14 PM
Portlander's Avatar
In a 2021 or newer F-Type Coupe, to disable the auto start/stop feature do you still remove the same plug in the same location as in the earlier models? Just want to make sure there were no changes to this procedure with the 2021 makeover.
Old May 16, 2023 | 08:37 PM
Thunderjet Racing's Avatar
the above plug disconnect worked for me
2021 P300
BEST !
RWS
Old May 17, 2023 | 08:08 AM
Portlander's Avatar
Disconnected the plug which eliminated the auto start/stop feature as it did in my previous F-Types. However, the yellow light remains constant unless I push the button which would be no different than if I kept the feature connected as far as physical exertion. So I covered the light with a slender piece of electrical tape and all is fine. Dwight Frye had the same issue so maybe the 2021 and newer vehicles are stuck with a continuous indicator light.
