Does anyone use their Headlamp Washers
Kidding aside, It's probably a good idea to use the washers occasionally to assure that they work. Otherwise the jets/outlets for the fluid could clog when you need them the most. Had that happen on several of my cars.
Nowadays, I verify the washers on all my cars operate properly, a couple times a year. The Jag's headlamp washers work every 4 or 6 windshield washings, you say? I'll watch for evidence. (Hopefully I won't need to detail the car first.)
I'm sure that Jaguar dealers sell a 'specification' fluid that prevents clogging, but I bet it costs $50 USD a gallon, too...)
I use my washers pretty regularly. This time of year the last mile heading home is straight into the sun, and I'd rather not do some impromptu rallying through the neighbor's yard, or Thelma and Louise into a gully.
As a side note, I have had someone behind me get mad at me for using my washers on the freeway. Some people use them as a middle-finger substitute for tailgaters, so perhaps he thought that, although he may have been upset at the water spots on his car. I just like to see where I'm going.
I've seen soap suds left behind on/around my headlights before... that's when I found out they even existed. I thought there was something seriously wrong with the car at first!
Magical (09-14-2018)
Received 2,183 Likes
they are supposed to come on when wash wipe and headlights are on. I hate the feature because ill have a clean car and a bug or 20 will hit the windshield so ill go to clean, only to be blasted with washer fluid now all over the hood. to disable buy a cheap hose pinch tool, vise grips etc and clamp the main single line behind the bumper before it splits off to the washers.
The following 2 users liked this post by Brutal:
Greggbhill (09-11-2018),
#30
They will come on every forth or fifth time you use your window washers EXCEPT if you have your your headlamps turned off. The headlamp washers will also spray if your headlamps are in "auto" I REALLY dislike them in that they overspray the hood and leave water spots on the hood and the headlight glass.
CRS
CRS
#32
#33
#35
#36
Received 3,114 Likes
Magical (09-15-2018)
#38
The following 2 users liked this post by Greggbhill:
Black15FTR (07-08-2020),
