Driver Side Window Issue
Old Feb 4, 2026 | 03:50 PM
wilhit10's Avatar
Default Driver Side Window Issue
I just bought a 2017 F-Type and sometimes have issues with my driver side window.
-Sometimes when I open the door, the window goes down about 1/2 way(not a 1/2 inch ). When this happens I have to close the door and roll the window up. If parking, I have to roll the window up with the door open, then close the door. When its like this, it will not auto dip correctly.
-The window will not go up/down constantly while holding down the button. I can not do a reset on the auto window switch as well.
I am thinking maybe the regulator/door switch is broken.
Any ideas would be greatly appreciated it.
-Adam
Old Feb 4, 2026 | 11:46 PM
sov211's Avatar
The first thing to do is reset the windows; the simple procedure is in your owner’s manual.
Old Feb 5, 2026 | 06:20 AM
wilhit10's Avatar
Thanks for the info, but I've tried .
Old Feb 5, 2026 | 11:04 AM
Vasara's Avatar
You might have moist inside of switchpanel. Use some warter repellant like WD-40 carefully and small amount in time.
It can take several go and even a week for a effect.
Old Feb 5, 2026 | 12:26 PM
sov211's Avatar
Well, the next thing might be to disconnect the battery for 30 seconds - this clears faults in the modules, and then do the window reset.
Old Feb 5, 2026 | 01:48 PM
scm's Avatar
scm
OzXFR claims his only works when he's actually driving the car.
Old Feb 5, 2026 | 02:20 PM
wilhit10's Avatar
It happens when I am trying to park the car. I was reading the service manual today and it does say if the window system feels like it gets jammed it drops 200mm. I will try to disconnect the battery and reset the window. I did order a regulator/w motor as sometimes the motor thinks it's getting jammed when its not.(I've seen this in BMW's).
Old Feb 20, 2026 | 10:11 AM
wilhit10's Avatar
Fixed:
Replaced the regulator and motor. This fixed my isssue.
Old Feb 20, 2026 | 10:38 AM
TangledThorns's Avatar
Fixed:
Should have recorded and posted a video on that.
Old Feb 20, 2026 | 11:14 AM
wilhit10's Avatar
I am not a youtuber, but willing to help anyone that has questions.
Pantera928
Dec 31, 2024 02:36 PM
powerlord
Oct 21, 2016 07:14 AM
dmo
Mar 31, 2015 07:32 PM
G-Man
Oct 22, 2011 10:56 AM
zmann96
Oct 25, 2010 09:49 AM
