Driver side window loose?
Hey everyone,
It appears that my driver side window has become loose. It moves much easier than the passenger side (which maybe is attributed to me rarely opening that door?) and squeaks. What holds the window in place? How can I tighten this to alleviate the issue? |
Originally Posted by dwilk
(Post 2518210)
Hey everyone,
Thank you for your response. What do I need to do after I get the door card off (or what do I need to look for)
(Post 2518270)
Originally Posted by Unhingd
(Post 2518358)
I suspect a nut has loosened attaching the track to the door.. Just check all the fasteners.
I tightened everything I could and it didn’t make a difference. There were some metal clips I saw that I adjusted, which made a minimal difference. I think the problem might just be caused by more usage of the driver side door vs passenger.
You should at least be able to figure out why it's loose. Wiggle the glass and see what bracket is not firmly attached to the glass and go from there.
Originally Posted by kb58
(Post 2518556)
Trust me, I tried, but all I could see were the little metal clips. Nothing adjustable at all. It’s possible it was further in the door but I’m hesitant to go further in fear of breaking something. At this point I’ll just have to learn to deal with it.
| All times are GMT -5. The time now is 07:11 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
