Drivers door handle won't pop open
Dropped my car off at the dealer yesterday and just received a call stating that it needs a new door handle actuator. The problem is that they searched Jaguar dealer parts deparments and no one has one in stock. It will be two weeks before they get the part. First it was the telecommunication module that needed to be replaced, and my car was at the dealers for one week and now this. I just got this car a short while ago and it only has 1000 miles on it. I hope this isn't going to be a trend.
Door handle problems
33,000 miles on my 2016 F-Type S Coupe and the passenger door handle won't permit me to manually lock or unlock it from outside. It took the dealer 1-week to disassemble the door and tell me I needed a new door handle. After waiting another 2-weeks for the part I was told that it would be yet another month before the part came in! In the meantime, the alarm beeps twice whenever I start the car. Sometimes the alarm beeps while I'm refueling the car or even driving along. Sometimes the passenger side window won't automatically raise all the way after closing the passenger door and, other times, the passenger side mirror won't retract when locking the car remotely. I've disconnected the ground to the battery a number of times to reset everything but that doesn't seem to work. The dealer says that the electrical gremlins are a result of the faulty door handle. I love the car but I never had any issues with Toyota, Lexus or Scion products. Then again, none of my 16 or so Toyotas have provided me the driving enjoyment that my F-Types have.
I had the same problem a few months ago on my 2018 that was only 4 months old at the time. They also took the door apart and discovered that I needed a new handle. I was told the part would take two weeks to come in, but it actually came in only one week. It ended up being that the door handle actuator was bad. It comes in as one unit which means that it has to be ordered in your car color. I got lucky that there was one available in my body color...
Passenger’s door handle won’t close
UNHINGD seems to know all the issues as well as solutions. He says that it is probably a door handle module and that’s what the Jag mechanic said.
As an aside, when living in Japan I learned that Toyota would actually find out who was on the assembly line installing the part and the contractor that manufactured the failing part. Contracts were terminated and/or assembly line workers were fined or worse. Quality steadily improved. Then again, that was 30-years ago. Things might have changed since then.
Interesting. My door handle was the cause of my battery drain. I replaced the battery first. Yes, they are painted when they arrive. The first one was labeled passenger side on the box, but the part was driver's side. Another week goes by and the second handle arrives and is also wrong in the box. the next one was the wrong color, they painted it, didn't like the results. Then they thought, let's move the electrical parts over to the old handle, Problem solved. I can't fault them for thinking of this last because it didn't occur to me either.
