Electronics issues
Old Aug 1, 2024 | 03:59 PM
Bam's Avatar
Bam
Default Electronics issues
I just acquired a 2016 F-Type Base V6 Convertible and have 3 issues:
1-Preset FM Radio Stations; I can set them, but if I turn off and exit the vehicle, when I return, the presets are gone.
2-Sub(woofer); does not work, pressing + or - across the scale has no effect on sound.
3-Navigation; does not work
I am on Maui and have no Jaguar dealer here. Can anyone help?
Old Aug 1, 2024 | 04:34 PM
Luc Lapierre's Avatar
Is the battery fully charged?
I've had a few strange issues with various electronics in the car over the years, but I can't remember any that weren't ultimately solved by hooking the battery up to my "smart" charger/maintainer overnight.
Worth a shot.
Old Aug 1, 2024 | 05:01 PM
cpq100's Avatar
After you exit the vehicle make sure the warning triangle on the dashboard goes out after ten minutes. If it does not your battery is being drained. To fix that you need to disconnect the ground lead on the battery for a minute to reset the battery management system.
Old Aug 2, 2024 | 10:32 AM
synthesis's Avatar
From what I can tell, there are many Jaguar dealers that are underwater, so perhaps one will float by one of these days.
Old Aug 2, 2024 | 03:35 PM
CJSJAG's Avatar
Don't worry, be happy!!
Sorry, wrong island in the sun.
Old Aug 10, 2024 | 01:03 AM
Bam's Avatar
Bam
Battery reads 12.8v to 13.0v, so not that. I was wondering if anyone may have had similar issues and hoping there might actually be technicians on this forum.
Old Aug 10, 2024 | 11:31 AM
clubairth1's Avatar
Community Influencer
I think the first step would be to get the car scanned with the Jaguar dealer level diagnostics which is called SDD? Independent shops and us individuals can also run this but it's not too common. Any chance you have a good independent import car repair shop? Might even be better than a dealer?
Old Aug 12, 2024 | 08:13 PM
bk000's Avatar
Sorry Bam - sounds like the head unit is messed up or maybe the prior owner tried to add an aftermarket Apple Car play or something. No NAV, no preset memory, and no subwoofer makes me think someone pulled the NAV unit and didn't hook it back up right - and considering that everything else is ok with the electronics in the car.
Do the steering wheel buttons for the radio adjust the radio (volume, etc.)? I'd try finding a replacement Nav/Radio head unit. It doesn't sound like a battery or random "electrical" gremlin.
AtTheJob
Jun 23, 2025 09:34 PM
jaguarguy100
Dec 11, 2022 04:17 PM
TX69XKE
Oct 2, 2022 07:40 PM
dannerbo
Oct 13, 2021 08:09 PM
Jlgti
Oct 8, 2017 04:07 PM
