F Type V6 S Convertible - Highway Drone
Recently picked up a 2014 V6 S and love the car. But when cruising on the highway in 8th gear at 75 MPH, where the RPMs are right around 2k, I get constant exhaust noise or drone everytime I lightly touch the throttle. This happens in Dynamic, Normal, or Snow mode. I checked to see if maybe the previous owner pulled fuse F43 to keep the active exhaust flap open all the time, but that was still in place.
Can other convertible owners chime in and let me know if this is by design? Or is my active exhaust not closing the valve/flap at lower RPMs? |
Is it a stock exhaust, or have previous owners fitted an aftermarket one?
I only get that once I've pulled F43, which powers down the active exhaust vacuum pump. I'd guess the valve, vacuum solenoid, or valves has failed.
Vacuum pump and solenoid are located behind the left rear wheel. My pump buzzes a lot around 1400RPM, and as my valves are squeaky, I can hear them open and close. |
Originally Posted by scm
(Post 2084443)
Originally Posted by DJS
(Post 2084446)
Originally Posted by Jaaaggg
(Post 2084708)
Yes, verified that it is the stock exhaust.
I am assuming something has failed, I don't hear any valves closing after it goes through the initial start up cycle. The exhaust is constantly loud. I am assuming no codes thrown is normal behavior if some mechanism fails within the AE setup. |
Originally Posted by Unhingd
(Post 2084900)
Maybe the previous owner pulled F43 fuse and never replaced it prior to sale.
(Post 2084911)
The OP has already checked that. ;)
I have a 2014 V8S and there was a problem fixed under warranty where the lubricant on the active exhaust baked off and they made a horrid squeaking noise when they operated. I expect, if not corrected, they'd eventually stick. This resulted in replacing the system and it hasn't had the problem since. But I'll bet the valves have stuck.
Originally Posted by enderle
(Post 2084930)
My active exhaust because passively loud when a rodent chewed through the vacuum line at the firewall. If you don't hear any difference at idle when you switch it, there's something wrong.
Originally Posted by lizzardo
(Post 2085696)
That’s the way it works, even with the electric vacuum pump. Open at idle, closed at a bit above idle, opens as revs increase.
On start mine's initially loud, but vacuum builds quickly enough that it'll quiet down. Once it comes off of fast idle, three's a noticeable difference between off and on. When that stopped, it was a sign that something was amiss. The vacuum leak was at the firewall right behind the symposer. Fortunately it was easy to find and patch. Not sure how they found it. Maybe smoke?
(Post 2085845)
(Post 2085879)
Depends on what they were smoking.
(Post 2085800)
Even with the switch off, I don’t think there’s enough vacuum to close the valves at idle. Mine won’t close until the engine RPM is up just a bit. Maybe that’s just at start.
Originally Posted by StormtrooperFtype
(Post 2087077)
Ya same with mine, on cold start its loud, then if the exhaust is off it quiets down but while the revs are still up if I turn it on it will make a noticeable difference, once the car is up to Temp I can here no difference during idle, when its off the valves dont close till 1500-1750 RPM then I can here them close, but then will open again after 4 or 5k rpm. Lately they have been rattling and squeaking, I am already on my third exhaust on the F-type, all replaced by warranty.
(Post 2087122)
I have noticed that the valves on the VAP exhaust are of superior quality as campared to that of the OEM valves. The return spring is also stronger, so the valve is less likely to rattle.
I would get the VAP exhaust 100% if it wasn't for the warranty issue, I know generally a catback or axleback would not void any warranty, but Since My cat's have been replaced twice already, I don't want to void the exhaust warranty either, Plus I'm still not sure if the car is going to be bought back by the dealer, Lawyers are going at it. Jaguar NA did offer me a few thousand in compensation for the issues I had with the car, but still fighting for the dealer buyback. Next car- Either R coupe or RS5 |
Best of luck!
