Front Splash Guards
Old Jul 9, 2020 | 03:17 PM
  #61
Unhingd's Avatar
Here's my plan::
1. Tabs will go down since the fat part of the guard is closer to the tabs.
2. The OEM tape (which will be removed) appears to be the 3M VHB #5952 Double-Sided Mounting Acrylic Foam Tape Adhesive (3/8" or 9mm). The 3/8" cannot be found so I have opted for the 5/16" (8mm).
3. I will measure the fender lip overhang at each of the insets to determine how much, if any, each of them needs to be individually notched.
4 . I'll start whittling on those guards tomorrow, but final installation will have to wait until I get the tape next week.
Old Jul 9, 2020 | 04:32 PM
  #62
FIRE550's Avatar
Nothing needs to be notched. Tabs cut them off, then doesn't matter which way you install them. There is not one way that gives you more protection.
Took off all factory tape that was on it and reused new 3m tape the whole length of the guard but maybe a half inch or so at top and bottom.
I have a couple thousand miles on them now and the clips stay on beautifully without issue.
The hardest part of the install is getting the guard to sit flush against the paint without any gap. I had to take them off a couple times to get zero gap. I am super ocd though!
Old Jul 9, 2020 | 06:56 PM
  #63
Unhingd's Avatar
I’ll be heating the tape and fender edge before I install to allow some repositioning. That may ensure a tight fit.
Old Jul 9, 2020 | 08:55 PM
  #64
Therock88's Avatar
Just a note for you on 3M Molding tape. It is not traditional adhesive, but rather has a cellulose structure that is PRESSURE activated. Just wanted you to be aware....Not that you cannot reposition it, but pressure is what will bond it.
Good luck!
DC
Old Jul 9, 2020 | 09:42 PM
  #65
Unhingd's Avatar
Good luck!
DC
Thanks for the heads up. I’ll play with the tape and a heat gun On something else first to see if my proposed strategy has any merit.
Old Jul 10, 2020 | 02:14 AM
  #66
FIRE550's Avatar
There is no need to heat the tape. Just when your installing put a little muscle into it when fitting them and they conform very well with no gaps.
Once I stopped being a bitch about it they went on super clean.
Old Jul 15, 2020 | 03:45 PM
  #67
Unhingd's Avatar
Just installed mine today. Thanks to everyone for your advice/suggestions.
Old Jul 15, 2020 | 05:51 PM
  #68
madmax1911's Avatar
Pics or it didn’t happen
Old Jul 15, 2020 | 06:31 PM
  #69
Unhingd's Avatar
ok,ok! Tomorrow morning.
Old Jul 15, 2020 | 07:20 PM
  #70
gg2684's Avatar
All lies, just buying time to actually do the project or divert attention away from the thread! Very disappointing Lance.
To all that did this, have you noticed a difference in debris on the side of the car or is more of aesthetic change to match the rear?
Old Jul 16, 2020 | 10:38 AM
  #71
madmax1911's Avatar
After changing the offsets and going with the wider tire it was obvious that the sides of the car were going to take a beating. The additional width of the splash guards will definitely help reduce the amount of road debris thrown up on the sides. The aesthetics are very pleasing to me as well.
A big thanks to Therock88 for posting this up.
Old Jul 16, 2020 | 10:49 AM
  #72
Unhingd's Avatar
​​​​​​​It happened, it happened.
And yesterday, too! Ha!
Old Jul 16, 2020 | 10:59 AM
  #73
madmax1911's Avatar
^ looking good.
Old Jul 16, 2020 | 11:55 AM
  #74
Therock88's Avatar
Very Nice! And will keep a little extra debris from smacking the sides!
​​​​​​​DC
Old Jul 16, 2020 | 01:54 PM
  #75
Unhingd's Avatar
DC
It certainly will. I noticed that the ppf on that edge of the wheel arch was slightly rashed. That now is totally covered by the guard.
Old Jul 16, 2020 | 05:56 PM
  #76
JgaXkr's Avatar
You should look into painting all 4 the same color as the car. They truly blend right in to the body work.
Old Jul 16, 2020 | 07:59 PM
  #77
Unhingd's Avatar
That is a good thought, but I’m too much of an automotive traditionalist (I prefer MTs, after all). Splash guards should be black.
Old Jul 16, 2020 | 08:37 PM
  #78
Tp10XKR's Avatar
Do you know how to tell if the modification was a success?
Months later after install, I don’t even notice the spats on my car as I walk by it, like it was factory installed all along and looking fabulous! Loved the spats on my XKR and now on my F.
Old Aug 8, 2020 | 09:40 AM
  #79
JeffreyB's Avatar
Default Looking for splash guards but am not finding local dealer help
Yes...You and I exchanged some posts in the other thread linked above, as I noted in that thread. Thanks.
DC
Tred to spend money locally but dealer never heard of splash guards...I looked for part numbers in posts but I admit I couldn't figure out from posts.
Do you have part numbers..for left and right guards for my 2014 v8s.
Old Aug 8, 2020 | 10:00 AM
  #80
cpq100's Avatar
Part numbers are:
C2P5094 - Right side
C2P5095 - Left Side
C2P5091 - Clips (you need 12)
BritCar has the best price but it will take a while for the parts to arrive. I called three local dealers and saved over $50 by using BritCar.
