Has Anyone Added the Carbon Fiber Hood & Side Vents?
I am contemplating adding carbon fiber hood and side vents. Has anyone in the forum done this and do you have pictures, or insight you can share?
Nope. But I note that they have no effect on performance, and save no weight (except in one's wallet).
Originally Posted by MI-FType
(Post 1096284)
(Post 1096284)
Cant for the life of me figure out why the stock vehicle, in any model, comes with the side vents (chrome) different than the hood vents (black), when they are shaped and styled as matching parts. As to Carbon Fiber accents, I saw a lot of CF trim on the dolled up Austin Martin cars in the adjacent showroom at my dealer, and I felt it all looked a bit contrived, but that is obviously a matter of taste. If you plan on replacing these components yourself, do a search on this site. It was quite a few months ago, but someone posted a fairly detailed description of how to replace the Side Power Vents. My recollection of the narrative is that it was a royal pain in the ass. Apparently very little room to get at that part. |
Originally Posted by SandmanTR
(Post 1096318)
I ordered the hood, side vents, side mirror and dashboard carbon fiber. Waiting on the new wheels to have my local shop install everything. I'll post pics once everything is installed.
Something aftermarket? or is this something you obtained through the parts dept. And by Dashboard, I suspect you mean the center console trim, which is a combination of three separate pieces...? |
1 Attachment(s)
Originally Posted by aJAGMan
(Post 1096409)
What CF dashboard component did you order?
It's between $750 and $850 in the US I think. Here's an online source: http://www.terrysjag.com/product/T2R5267.html |
(Post 1096318)
I want to see the CF diffuser! Anybody?
(Post 1096284)
Originally Posted by F-typical
(Post 1096314)
Originally Posted by shift
(Post 1096683)
I want that rear diffuser and front grill ! As for the CF side vents, have you looked at the Jaguar directions for removing the old ones? It says to drill a 3/8" hole in the old vent feed a cable tie through it and rip it off the body. They just snap in place but it looks impossible to reach the clips to release them. I have a set of CF side vents but I am waiting to see if some one comes up with a better way to remove the old ones first. |
Originally Posted by Kjamo
(Post 1096707)
I thought about adding this option - my dealer said it was $2500. Does that sound right?
Hood vents.
See my post on hood vents installation. Hope it helps!!!
https://cimg3.ibsrv.net/gimg/www.jag...dd65e084f3.jpg |
...and 'Related Threads' strikes again.
Actually, Pavedragon just posted a pretty motivated vent install thread in the XE forum, I suspect he didn’t notice this thread hasn’t been touched in 9+ years.
The gloss black accents on my Silicon Silver P380 just didn't stand out enough for me, so I went the whole hog and fitted carbon fibre wherever I could; bonnet vents, wing (power) vents, mirror covers, rear diffuser and centre console trim. Engine cover excluded as the original was removed for cooling/weight saving.
@F-typical Although the switch to carbon fibre will not save many lbs, being fanatic about losing weight off the car, I did measure the differences between the original gloss black items; Bonnet vents = 30g saved, Mirror covers= 70g saved, Power vents = 140g saved, Rear diffuser = 1,565g saved, Centre console trim = 40g gained! So yes pure cosmetic exercise, although the diffuser was reasonable in terms of £/g ratio. Anti-gravity battery is the best lb/£ saving by far. @schraderade The centre console trim retails at £230 inc taxes here in UK from Britcar, much less than US prices, same price for RHD or LHD, however LHD listed as obsolete, so may require some searching around Europe. @JagMan note the centre console upper trim officially only fits vehicles with the 8" screen, as the housing is different to the 10" screen, however by removing the front clip lugs with a dremmel, you can make it fit above a 10" display, where it remains secured by the centre vent housing. @shift As far as I'm aware, Jaguar only produced a carbon fibre rear diffuser for the V6 cars (although this also fits the P300 4 pot). It does seem to be a very rare fittment, at the 10th anniversary Jaguar F-Type meeting back in April this year, where around 250 F-Types were present, I could not find another car with it fitted. As you asked for a picture here you go - https://cimg0.ibsrv.net/gimg/www.jag...0b1feb74cf.jpg As for insight, no pictures of any of the installs I'm afraid, although I would list them in the following order of ease of fitment: 1. Bonnet vents, just pry clips loose with bonnet raised, helps to have helper on outside to catch vents as they come loose. 2. Centre console trim, 15 mins with some pry tools, except if you have to modify to fit 10" screen. 3. Mirror covers, no screws, just clips, but requires caution to avoid damaging clips on original mirror covers. Search for how to videos on YouTube. 4. Power vents, yep, pain in the @$$. See thread referenced above. You can remove originals with combination of pry tools, microfibre towel padding and cable tie threaded through mesh to provide pull handle. Need to be really careful to avoid paint damage and almost inevitably you will damage one or more clips on original vents. Jaguar instructions --> Side Power Vent 5. Rear diffuser, Jaguar provide an estimated fitting time of 42 minutes, which is wildly optimistic in my view, lots of screws, trim pieces, rear fog light/reverse light, to be removed replaced. You will need to purchase the newer clear lense rear lights if you have the old style red/white lenses in addition to the diffuser itself. However, all that said, it is a straight forward job, just don't expect to be finished in 42 minutes! Jaguar instructions --> Rear Diffuser V6 |
Here ya go
https://cimg0.ibsrv.net/gimg/www.jag...c77231272d.jpg
I have the Hood, Vents, and Mirrors. Here's a pic. Where in Michigan are you located? I live in Holland. |
I have a 2014 Jaguar F-Type V8S Convertible and I have added the carbon fiber Jaguar accessory 3 piece dash console parts. I like the look over the standard 3 piece console parts especially when the top is down the parts have a very nice "depth" to them. I also have the hood, side vents, and roll bar parts in carbon fiber which I am getting installed in a few days. All original Jaguar parts.
https://cimg1.ibsrv.net/gimg/www.jag...3bb0b35d33.jpg https://cimg2.ibsrv.net/gimg/www.jag...d7b23e6042.jpg https://cimg3.ibsrv.net/gimg/www.jag...3a6f32f726.jpg https://cimg4.ibsrv.net/gimg/www.jag...3db57aed20.jpg |
I do carbon fibre parts as a hobby so if anyone in Australia wants replacement parts (fully new parts made completely from CF and resin), or wants existing parts skinned in CF (a thin layer of CF over the top of the factory part), send me a message. Either option would require you to send your part to me for about two or three weeks as I don't have any Jaguar molds yet.
If you're the first person to send me a part to make a mold from, I'll wear the shipping and mold costs and I'll do your parts for just the cost of the carbon materials ;) |
| All times are GMT -5. The time now is 08:58 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
