Torque Limiter
Torque Limiter
I'm trying to figure out why my car has torque limitation programming in the ECU. I have a 2017 Base 340, which has a maximum torque of 332 ft/lbs. According to Wikipedia (https://en.wikipedia.org/wiki/ZF_8HP_transmission - best source I could find), all F-Types use the ZF 8HP70 transmission, which has a maximum torque of 700 ft/lbs.
I can't go over 700 ft/lbs, so the tranny is limiting the measly 322 that I have? HUH????
Could someone who understands these things please educate me?
Your transmission is RATED to hold 700 Nm of torque (not lb-ft). The engine you have is only tuned to produce 332 lb-ft (451 Nm) and isn’t limited by the transmission calibration from a peak torque perspective.
Interestingly enough, going to the S or P400 will only net you 339 lb-ft (460 Nm) of torque even though you’re gaining 40-60 bhp because they only limit you on the top end between the different V6 trims.
Note: 700 Nm of torque = 516 lb-ft which is convieniently the max torque on the V8 models.
FullChat (05-30-2018)
Thanks for the Nm lb-ft correction. Ooops!
I was just thinking about a tune and had heard that the torque limits were put in to save the transmission, and worried that the tune might be giving me more torque that the tranny could handle. Then I found out that all of the F-Types use the same transmission and thought - if it can handle a SVR, it should be able to handle a tune!
REDTYPE
09-28-2015 12:08 AM
al_roethlisberger
09-30-2014 04:50 PM
