How to raise engine noise in cabin?
The v6 f-type sounds absurdly good from outside the car, but I’m disappointed with the lack of engine feel/sound from inside the cabin. I’ve tried dynamic+sport mode (passive exhaust). It’s almost like someone cut most of the low end out of the sound. It does sound better when it’s very high revs, but still feels strange to me, like it’s distant.
I saw one post where someone removed sound deadening to help more engine sound enter the car. If anyone has tried that, did it work for you? I realize road noise would increase but I don’t think that would bother me. Aside from that, is there an exhaust modification recommended that doesn’t make things too raspy? |
Originally Posted by maxiedaniels
(Post 2058306)
Originally Posted by Unhingd
(Post 2058321)
Add a VAP Valvetronic exhaust. It’ll provide plenty of internal sound with no raspiness if you keep the OEM downpipes.
Never mind the increases in power, torque, responsiveness and performance! |
I find a cost effective solution is lowering the windows to increase the sound inside...... :icon_smile:
agreed, if we could lower the rear windows the problem would be solved. The sound inside is incredible if they are taken out (which I did in my XKR)
Or..... get the Vert!!! Always a decision of listening to tunes or the exhaust symphony! ;)
My car is so noisy inside I can’t speak to people when in dynamic mode; I need to turn off the exhaust for phone calls or passenger conversations
Lolll. Unfortunately windows down doesn’t fix things for me.. interesting about the VAP mods, will research more. Thanks!
Originally Posted by jbajor
(Post 2058401)
(Post 2058306)
Originally Posted by fujicoupe
Have you looked into adding the Internal Sound Enhancement feature? I believe it's called a Symposer, although it may only enhance engine sounds and not exhaust notes--don't know as it is not an active feature on my car.
Originally Posted by Nati
(Post 2058560)
Pretty sure that's not a choice. I think it's on every F type.
(Post 2058574)
No, it is not on every F-Type; it's not on mine. From the build sheet provided when I purchased the car: "G27Z LESS Internal Sound Enhancement"
(Post 2058614)
Interesting. It's not a configurable option according to any of the order guides I've seen.
(Post 2058574)
