Introducing Me
Old 04-14-2019, 05:35 PM
AJB2's Avatar
Hi unhinged. Numbers are 18...let’s see what you find...
Cheers.
andrew.
Old 04-14-2019, 05:39 PM
AJB2's Avatar
Tel...It does say Copart (Special Vehicle Operations). What does this mean then?
Old 04-14-2019, 05:45 PM
AJB2's Avatar
Originally Posted by Tel
Sounds like a rather interesting car...
@AJB2 Maybe Jaguars' OSH may be able to shed more light on where it's been and from. https://osh.jaguar.com/
Hoping not to see the word Copart in there! ;-)
It does have Copart (Special Vehicle Operations)
Old 04-14-2019, 06:03 PM
AJB2's Avatar
This is how it is written
Copart (Special Vehicle Operations)Acrey Fields, Woburn RoadBedfordshireBedfordshireMK43 9EJUnited Kingdom01234 762213B561630/11/20166699 miles
Service Completed16000 miles / 12 months serviceOther Related ItemsRenewal of Oil and Oil FilterRenewal of Brake FluidRenewal of Pollen FilterRenewal of Engine Air FilterRenewal of Alarm Handset BatteriesAir Conditioning Service
Old 04-14-2019, 06:12 PM
AJB2's Avatar
Then This
Inchcape Land Rover, Guildford1 LadymeadGuildfordSurreyGU1 1DTUnited Kingdom5499918/09/201818197 miles
Service Completed48000 miles / 36 months serviceOther Related Items
Old 04-14-2019, 06:22 PM
jaguny's Avatar
Is that link to Jaguar's Owner's club only for UK owner's. It does allow selection of USA as location, but it says that online info not supported for my vehicle?
AJB2 (04-15-2019)
Old 04-14-2019, 08:40 PM
SinF's Avatar
Received 2,140 Likes on 1,461 Posts
No way Jaguar road-tested for 2 years and not seen slipping clutch issue. I am skeptical that OP somehow got an early MT prototype (that probably never existed) and it was updated with a later dash and so on.
It is typo in a document or hoax or VIN rebadging to hide bad title history.
  #28
Old 04-14-2019, 10:08 PM
Unhingd's Avatar
Received 4,636 Likes on 3,359 Posts
Cheers.
andrew.
Based on production sequence number, the car was definitely built during the MY2015 production cycle (March 2014- February2015). The features indicate an MY2016. If the VIN truly belongs to this vehicle, you have a rare pre-production unit that was used for real world testing or produced as a press vehicle. Given the production date, most likely the former. Other than this car, I know of no regular production MTs with a sequence number of anything less than a 27xxx.
Old 04-15-2019, 12:45 AM
AJB2's Avatar
I can honestly say that the VIN truly does belong to this vehicle. As previously stated, it came from Inchcape Jaguar Guildford with a full 2 years Jaguar approved Warranty. So, what is it I actually have here? Whatever it is, it has certainly landed on its feet as I’m fanatical about my cars & tend never to sell them on. Just to add, I also have the full build Topix sheets as well.
  #30
Old 04-15-2019, 12:48 AM
AJB2's Avatar
  #31
Old 04-15-2019, 01:28 AM
AJB2's Avatar
Unhinged...I cannot for the life of me get the car to repeat the “Clutch Slip” I’m now wondering if, due to the danger of the situation I was in when it happened, If it was the rear wheels spinning causing the lack of grip & smell? To be honest, I just needed to get out of the situation fast & didn’t take a lot of notice what was happening...the smell was like hot brakes...
  #32
Old 04-15-2019, 06:07 AM
jaguny's Avatar
How many miles on the car when you purchased it?
  #33
Old 04-15-2019, 06:44 AM
AJB2's Avatar
18,197 Miles
  #34
Old 04-15-2019, 07:22 AM
DJS's Avatar
DJS
DJS is offline
Received 2,064 Likes on 1,369 Posts
Did you check the label on the drivers door sill that gives manufacture date, etc?
  #35
Old 04-15-2019, 07:26 AM
vika01's Avatar
Originally Posted by scm
Sure looks like a 2014 to me.
first of all. If it’s a manual it’s a 2016-2017. Second of all the start button is black and the shifting paddles are silver. Therefore it’s 100000% a 2016 model year.
  #36
Old 04-15-2019, 07:27 AM
Unhingd's Avatar
Here's the test:
Do a full throttle zero-60 run with a fast 1st to 2nd shift. If you have the dreaded 1st generation clutch, the clutch will not fully engage in 2nd gear and will just initiate a meltdown until you let off on the throttle. Then it will catch and act like a clutch in good condition. Gentle drivers will never experience this slippage.
Your description of the situation certainly indicates you have this issue.
AJB2 (04-15-2019)
  #37
Old 04-15-2019, 07:28 AM
SinF's Avatar
Get a different shop compare VIN numbers and make sure they match. There is one stamped on the engine block, one on dash and there are couple other hard-to-get to places. If they all match, then it is what it is. Document this.
A unicorn, one of a kind car that is probably collectable, or you are a victim of a scam.
  #38
Old 04-15-2019, 07:30 AM
Unhingd's Avatar
Yes, it is a model year 2016, but apparently built in 2014 as a pre-production-cycle road tester.
AJB2 (04-15-2019)
  #39
Old 04-15-2019, 07:33 AM
scm's Avatar
scm
scm is offline
Received 1,383 Likes on 1,050 Posts
I'm not disputing the MY, see my previous post for the explanation of the registration.
  #40
Old 04-15-2019, 09:02 AM
SinF's Avatar
If that is the case, we know it was driven very gently all the time and never seen track use.
AJB2 (04-15-2019)
Quick Reply: Introducing Me
