More blower noise
So im on a quest to get more SC whine. I've searched through the forums using the search bar and have read all the threads i could find relating to intakes, but havent found exactly what im looking for.
Im not trying to get any more flow through the intakes , i just want more induction noise, I understand the SC on the F Type is made to be quiet, but near redline it sounds so good. On the diagram below i think #3 & #4 are silencers for the intake system, has anybody tried removing them ? I know the Eventuri intake replaces it, but im not looking to spend $2k just for a slight noise increase. Has anyone else done anything to get more noise from the SC/intake. I'm thinking of getting the lower pully from VAP, but that probably wont happen till later this year. I have also removed my engine cover, and that did help make it a bit louder https://cimg8.ibsrv.net/gimg/www.jag...67678b2ec9.jpg |
When I had an STI, there was an intake elbow used to silence the turbo noise that we'd remove. It was before the air filter panel too.
Does the aftermarket intake like the Eventuri make increased noise? |
Originally Posted by jfranks
(Post 1613962)
On the XF SC and XFR some have increased the blower noise a little by cutting off the resonators then plastiwelding a cover piece over each hole.
Two of them on the F-Type, on the under side of the top/centre pipes, number 9 in the pic and the same just under part number 8. |
There are three insulating foam pads around the supercharger, one underneath, one on each side, take them out you'll get more noise.
But! They probably serve a purpose of insulating heat too... |
The quiet supercharger is one of the only design letdowns of the F-type - all personal taste of course.
I loved the whine of my Ford Lightning and a Dodge Hellcat with the proper CAI is glorious sounding. |
More supercharger whine would definitely be on my wishlist as well.
This is the second supercharged car I have owned , had a supercharged Lotus Elise around 8 years ago and replacing the standard airbox with a factory TRD one gave the most amazing whine., absolutely loved it Wish Jag offered an alternative to stock, maybe the SVR team could develop something. |
I personally don't like blower noise, for that reason outside track days I always put engine cover back on.
Call Chris at Mina Gallery --- he just made aluminum intake tubes for my f type and they eliminate noise restrictiors and look very cool and only cost a couple hundred $
Originally Posted by frank james
(Post 1614214)
Originally Posted by OzXFR
(Post 1614215)
Pics or it didn't happen!
If you want more information and pictures --- look up Mina gallery online and look up XFR ---- performance items -they look the same as for the f type --- he does show them for f type yet but they are available ------ mine were installed on my 15 f type r a few weeks ago ----- he has lots of other Carbon fibre parts also not shown online
(Post 1614232)
Here's a weird one for you. Drove my friend's 2WD 'R' extensively, it's the one in our exhaust videos. After we put a tune on it - supercharger noise increased substantially. And that was independent of actual boost levels. Going through the changes in the software I don't see a reason but then subsequently multiple customers reported the same after we tuned their cars.
Still don't know exactly why, but it seems to be repeatable. |
Stuart,
It sure seemed like the supercharger was louder to me, but it's so subjective. And I was running it pretty had to test the tune. I need more time with it. If you build something that will give us the ability to hear the whine better, put me in line for the first V8s run! Mike |
Will do Mike. You get that exhaust fitted yet?
Not yet.. it's been raining and I want some dry pavement to get the pre-install video. Got a little video when it was dry, but the GoPro was too far out in the wind so the sound wasn't great.
Mike |
There is - presumably - a bit of plumbing between the s/c outlet and the throttle body that dumps excess boost back to before the s/c intake. If that were disconnected and vented to atmosphere...
Originally Posted by F-typical
(Post 1614323)
Originally Posted by Stuart@VelocityAP
(Post 1614257)
(Post 1614323)
