Must Replace rotor?
I inquired at my dealer what the labor cost is to replace the brake pads.
They advised $290.00 for the front and $290.00 for the rear. But! You must change the rotors too as they cannot be turned. Is this the fact jack? Is this true? |
It is unlikely you need new rotors on 2016 unless there is an issue. More so, I heavily track my car and I am still on original pads and rotors.
However, YMMV as I rarely use brakes outside of track situations. |
I only wanted to change the pads to get less dirty dusty messy pads. No real issues other than dirt.
Most dealerships will claim that the rotors also need replacing every time the pads are renewed.
They usually claim "for maximum braking efficiency and peace of mind you need to renew both at the same time". IMHO and after lots and lots of research and experience across two XFs and the F-Type this is BS and simply a standard con from the dealership to generate more revenue from unnecessary rotor replacement. I had the OEM rotors on both the XFS and XFR turned/machined when fitting new pads the first time (not long after I bought each car) and not a single problem, the brakes worked perfectly afterwards. As we know the OEM brake pads on the F-Type wear fairly quickly and so do the rotors, as they are both fairly "soft", and a good portion of the massive amounts of brake dust you get with OEM pads and rotors is actually from the rotors not just the pads. But in 99% of cases you should easily get two fully worn out sets of pads out of one set of rotors. The idea is to measure the rotor thickness (all four) when you are ready for a pad change and determine if the rotors are within minimum thickness spec or not. If they are thicker than minimum spec you are good to go for another set of pads, if under minimum specified thickness then at least for insurance purposes you should renew the rotors as well. According to the Workshop Manual the specified minimum thickness for all Jag rotors is 2 mm less than new. For example with the F-Type "super performance" brakes (380 mm front and 376 mm rear) front new rotor thickness is 36 mm / 1.42" and minimum thickness is 34 mm / 1.34" while rear new rotor thickness is 26 mm / 1.02" and minimum thickness is 24 mm / .94". So JLR are saying that 2 mm of wear or a whopping 1 mm each side takes them to minimum specified thickness, which IMHO is excessively pessimistic and the rotors are almost certainly still perfectly OK at another 2 mm thinner, especially the fronts. But of course you take a risk running rotors slightly under minimum specified thickness that the insurance company might deny a claim. Bottom line - don't take the dealer's word for it, measure the thickness of all four rotors yourself (very easy to do with a vernier caliper) and then decide if you want/need to replace them. If you decide to keep them it is always a good idea to get them skimmed when fitting new pads. |
Originally Posted by Don1954
(Post 1961152)
Originally Posted by SinF
(Post 1961333)
Bad idea. Dust is the lesser evil. Alternatives are noisy pads or pads that won't work as well as OEM.
Don, I concur with OZ that new rotors are unnecessary unless you are pushing 50 or 60k miles. No one will turn the rotors, as the brand new spec is probably identical to the minimum spec in the maintenance book. Even if your rotors have a few minor ridges in them, the new pads will conform perfectly within a couple hundred miles. |
(Post 1961146)
The OP (Don) stated that the pads are not worn out, he just wants a less dusty pad/wheel.
Of course, the most accurate response is to 'measure rotor thickness first, then decide for yourself'. If a dealer won't do it that way, go to an independent shop. (Which I would do anyway, its not a warranty situation at all...) That said, I think that Jaguar's conservative wear specs are because the rotor DOES contribute to heat dissipation. If it's too thin you are on 'thin ice' to coin a phrase. :icon_angel: Even if you really want to get your money's worth, don't let yours wear this far, OK? https://cimg5.ibsrv.net/gimg/www.jag...292d7664c9.jpg Or https://cimg5.ibsrv.net/gimg/www.jag...d05fc676f8.jpg |
At least part of this is the dealer is covering themselves in case of a come-back. If they replace the pads only and the brakes have issues, such as squealing, they'll have to do the job again on their own dime.
I never turn rotors, but also do my own brake work. I save on labor, and replace rotors with pads because I don't want to go back in. I've got more interesting things to do with my time. I may feel differently with my expensive two-piece rotors when the time comes, but my micrometer will have the final say. |
Thank you all
Thanks you all for your replies and techno advice.
Car has 11k miles, no issues other than dust. Looked up Porterfield prices for pads, decided to wear mine out first. Cleaning wheels is therapeutic right? |
Originally Posted by lizzardo
(Post 1961620)
(Post 1961666)
(Post 1961666)
The majority of high performance cars all produce insane amounts of brake dust. Very common topic across car forums of all makes and models. My last two Porsches were both horrible - certainly some pads where better than others, but still all were bad. |
I need to learn NOT to lick my finger after I touch the wheel to see if its dusty. (It always is :icon_mad: )
:icon_special: |
(Post 1961666)
