5w30 oil!!!
Old 03-06-2019, 02:30 PM
mohammed m's Avatar
Default 5w30 oil!!!
hi guys
can i use 5w30 to my jaguar ftype r v8 AWD
or i have to use the recommended one w20????
Old 03-06-2019, 03:11 PM
addict's Avatar
Originally Posted by mohammed m
hi guys
please use the recommended oil on your new engine and be careful not to overfill it
Old 03-06-2019, 03:20 PM
OzXFR's Avatar
Received 3,114 Likes on 2,297 Posts
Recommended is 0W20 but 5W20 is perfectly OK and is arguably better than 0W20 in a hot climate.
But 5W30 is a big NO in the F-Type V8 or V6 engine.
Old 03-06-2019, 03:36 PM
scottjh9's Avatar
You can look in your manual maybe and see if there are other weights that are approved
Old 03-13-2019, 01:16 PM
Terrance39's Avatar
Just finished an oil change in my 15 R. Oil weight plays a big role with clearances etc. I myself at first thought the oil is really thin for a performance car like this. But bearing clearances etc was set with this type oil weight in mind. So I usually don't mess with what the factory recommends.
FType17 (03-13-2019)
Old 03-13-2019, 01:42 PM
scottjh9's Avatar
Same here... i don't think the newer cars have as many owner's manual choices as the older ones...my 06 str has 6 approved weights i believe....never seen a newer manual though
Old 03-14-2019, 05:18 AM
TimG.'s Avatar
This has to be a wind up!
Old 03-14-2019, 05:27 AM
Received 4,435 Likes on 2,421 Posts
RTFM
NigelW (03-14-2019)
Old 03-14-2019, 06:50 AM
Unhingd's Avatar
Received 4,636 Likes on 3,359 Posts
Originally Posted by Cambo
RTFM
Unfortunately, that won't stop the discussion about heavier viscosities.
Old 03-14-2019, 07:04 AM
Carbuff2's Avatar
Hell, no! Car guys LOVE a good oil discussion.
Old 03-14-2019, 09:56 AM
DJS's Avatar
DJS
DJS is offline
Received 2,064 Likes on 1,369 Posts
RTFM
Nice doc, thanks. Says it doesn't apply to US/Canada, but I assume that's because they're not selling Magic Elixir #2 here yet.
For those who haven't read it, it replaces our beloved Castrol EDGE Pro with Castrol Edge Pro C5, except for the AJ126 in cold climates...
Castrol EDGE Professional E C5 0W-20, which has been jointly developed with Jaguar Land Rover, improves
fuel efficiency and reduces CO2 emissions* while maintaining the reduction in metal to metal friction and wear.
The Castrol EDGE Professional range is the only engine oil recommended by Jaguar Land Rover.
* In tests versus Castrol Edge Professional E 0W-20
Old 03-14-2019, 02:39 PM
Unhingd's Avatar
Personally, I'd opt for the non-C5.Temperature-wise Chicago is 5 degF colder on average in January than Stockholm.
Dan_NL
11-22-2018 04:31 AM
Sixx Dogg
12-02-2016 06:52 AM
Terry007
10-02-2016 01:46 AM
Rambunctious Jaguar
73
05-05-2014 07:39 PM
jag79
52
11-08-2010 06:16 PM
Quick Reply: 5w30 oil!!!
