Oil filter Wrench Source
for those perform their own F-Type oil changes, whose oil filter wrench do you use? I bought a 90mm 15 flute one from NAPA and it is a plastic POS that is too big. Any recommendations?
Originally Posted by RGPV6S
(Post 1978044)
https://asttool.com/detail_page.php?...nge%20Products However, unlike my direct orders to Assenmacher in the past, I had to order the oil filter cap from ToolSource.com (Assenmacher directed me to them). The cap shown in the below ToolSource.com link is the oil filter cap made by Assenmacher. https://www.toolsource.com/oil-filte...b216eln6o1vq43 BTW, I tried the plastic oil filter caps too (don't ask how many I have collecting dust). Think I've finally learned my lesson. Steel is the only way to go if we're talking about oil filter caps. |
I bought one similar to this a few years ago, cheap as chips from my local auto parts store and works a charm: https://www.ebay.com/itm/STEELMAN-06...wAAOSwnN9btxu4
The beauty of it is it is a universal fit and I have used it on several cars, and it has loosened off a couple of really stuck hard filters. But don't get the one in the linked ad, you need one that looks damn near identical but the inner edge of the strap (where it grips the filter) is covered in a 1/4" thick strip of rubber. I couldn't find one exactly like that on Fleabay but auto parts stores should have them. |
I got the Steelman 06128 from Amazon. (It's smaller than the picture, LOL)
https://cimg8.ibsrv.net/gimg/www.jag...f4a349dd6a.jpg |
Originally Posted by Carbuff2
(Post 1978185)
Looking for some direction, I have a 2015 3.0L Ftype s and purchased a 90mm 15 flat cup wrench, and it is too big. My measurements would suggest an 87mm, has anyone purchased one, and what size was it?
I ended up using one of these I found in the back of a drawer in my tool chest. Just put sections of thick latex lab tubing on each jaw to prevent scratching.
https://www.homedepot.com/p/Husky-Un...3JFW/204762449 BTW what ever you do do not buy one of the oil filter sockets made of plastic they will be useless - even if it is the correct size. Initially that was all I could find locally and both I tried I had to return. |
I’ll measure mine when I get home tonight. |
(Post 2034692)
Originally Posted by Unhingd
(Post 2034787)
That type of wrench works well if you have a spin-off filter that gets disposed. I wouldn’t want to use it on a permanent filter housing. Although the other one did work fine with once I put the rubber tubing on it. |
Originally Posted by 68etypejagman
(Post 2034684)
Using a caliper gauge, the flutes on the filter housing measures 87.5mm. My wrench measures 88mm. The proper wrench is an 88mm x 15 (flutes). A google search will net lots of results. EDIT: Thinking further about this, since the wrench and filter housing have an uneven number of flutes, I am uncertain exactly how to measure them. The right wrench might also be an 89mm x 15. |
I bought this one from Amazon...............it states it is specifically for Jaguar, although it is classed as a 90mm x15.
It works on my V6............. Motivx Tools 90mm 15 Flute Oil... https://www.amazon.com/dp/B01BS6M04I?ref=ppx_pop_mob_ap_share |
Originally Posted by magredvet
(Post 2035097)
Well bought the Steelman 06128 as was suggested elsewhere in this thread. Was just delivered and it it too big. Now I have another paperweight.
Following Lance's recommendation for one with 88 mm internal diameter and 15 flutes I searched Fleabay for one with those specs and found a real cheapy, $8 IIRC.
It should roll up any day now, when it does I will do a test fit and report back. |
Originally Posted by OzXFR
(Post 2038440)
(Post 2038478)
I did some research. Turns out I have the 90mm wrench which fits loosely but will round off the plastic flats on the filter housing if there is significant resistance. Knowing my luck, the right wrench may be an 89mm x15 rather than 88mm x 15. My apologies if that’s the case. |
(Post 2038562)
It cost me a whopping $14.80 AU (a tad more than the $8 I incorrectly recalled) so if it doesn't fit I'll just put it on your bill Lance!
Can't find an 89mm version so I think we are down to either the 88mm or 90mm which looks to be too big.
Just ordered Steelman 6138. 15 flute by 88mm. About $10 on EBay. They are listed for a Hyundai. Just got my 90mm version Steelman 6128. Fits with some slop so I could see it doing damage to the plastic oil filter housing. I did like the tin foil solution! Good thinking. . . . |
